Radiator fan replacement
Old Dec 13, 2017 | 08:31 PM
90toyoprobs's Avatar
Hey guys my radiator fan needs replaced on my 1990 Toyota pickup with the 3.0. I was just wondering if there were any better options than the gross looking plastic stock fan
Old Dec 14, 2017 | 03:48 AM
wyoming9's Avatar
Red face
How did you break your fan??
I am sure if you search you can find a fancy fan that costs big bucks and does the same or less moving of air
You could research Electric fans but they tend to fail at the worst time
Old Dec 14, 2017 | 05:43 AM
se7enine's Avatar
It's only ugly because it's almost 30 years old. Plus you can't see it when running and surrounded by the shroud. I say spend the $80 or so dollars on another Aisin fan and wait another 30 years and see if they have cooler looking fans by then.
Old Dec 14, 2017 | 07:36 AM
scope103's Avatar
A new (stock) fan would really dress it up!
Amazon Amazon
('course, you could buy a lot of fuzzy dice for $80, just sayin')
Old Dec 14, 2017 | 11:13 AM
well the biggest thing about it is the shroud like thing on the fan itself not only do I not like the looks I feel like itd be putting unnecessary stress on the fan mount plus I was just curious if there were any suggestions for better performance
Old Dec 14, 2017 | 12:07 PM
scope103's Avatar
So you have THIS https://www.ebay.com/itm/1636165010-...-/182596869512 style fan?
The online dealers https://parts.lakelandtoyota.com/sho...rimLevel=18292 show both 16361-65010 and 16361-38010 as fitting our trucks. I have no idea if they are really interchangeable. If they were, I would be more likely to choose the one with the "shroud like thing." I doubt the stress on the fan is significant at all, but it looks like it would do a much better job of cooling. And lack of cooling really stresses everything.
Old Dec 14, 2017 | 12:15 PM
old87yota's Avatar
The shroud part of the fan shouldn't be putting unnecessary stress on other components. I think Toyota would not have designed the fan like that if it were to cause something else fail.
However, there have been instances were the plastic gets old and brittle and the fan breaking apart (~30 years is probably twice the life expectation of the truck when they were built).
The stock fan and fluid clutch setup is actually a really good cooling setup. Many people who "upgrade" to an electric fan struggle to achieve the same amount of air flow that the stock fan can put out.
I don't have a 3VZ-E so I have not looked into alternative mechanical solutions.
If you are worried about the fan becoming brittle, I would just replace it with a new Aisin fan (OEM fan).
Old Dec 14, 2017 | 01:58 PM
Co_94_PU's Avatar
The ring on that style fan makes it more efficient, it keeps the air from sliding off the ends of the blades similar to the vertical section on the tip of an airplane wing.
jstluise
Jul 30, 2013 11:49 AM
twowheelwarehouse
3.4 Swaps
Jul 11, 2013 09:26 AM
greenz02
Oct 18, 2011 12:14 PM
Blacksmith04
Apr 13, 2008 02:24 AM
2wheeler97
Nov 14, 2002 08:37 PM
