quick question
quick question
i was reading around the internet and i cam across a forum were guys were putting the 80 series land cruiser coils on rears and 1.5bj up front and they said
"using a 3" lift in the rear matches the 1.5" bj spacers in the front really nicely"
my only question is how can you have 3" in the back and 1.5" in the front?
are the ome 895 the lc coils i need
http://www.offroadtuff.com/ometoyota.htm
and if they are is thier a place to get them cheaper
I know when I was looking... OME seemed to be the most popular for the coils.. I was planning on using their shocks aswell. Keep in mind, you may be able to get away cranking up your T-bar up front about 3/4" to 1". Might not have to use the ball-joint spacer, but.. it will be a rougher ride.
No, you need pre-sagged used and abused old LC coils of an 80 series. You're welcome to try to use 60 or 70 series springs, but you might run into a wee problem with them
You're going to have a brutal rake with LC coils and BJ spacers. I think you're better off with OME medium duty 4Runner coils and BJ spacers.
Here's how my truck sat before, with saggy coils:
With OME 900 (medium duty) rear coils (doing some hard core rock crawling):
I got some kind of performance coil that was added to my truck in the 90's, from Germany, and I'll tell you, those things are impressive. wish I knew the brand name. 15 plus years of abuse, and they still don't sag, and they flex very well.
the progressive rate springs...
My dads got those out back on his runner and they give it a nice stance
I'm not sure, the previous owner put them on. he did that at 17k miles, now the truck has 212k miles, and is still raked forward, gives it a real aggressive look.
Better at what? They're still going to lift it ~3" beyond what the OMEs in the second picture did.
Basically, what I was implying is that they lift the rear too much for bj spacers, you really need a bracket lift to level it.
Another thing to keep in mind is that with a huge rake, the steering is going to be very weird as the caster angle changes and cannot be corrected for.
