Questions on manual hub swap?
Old Jan 27, 2007 | 12:00 PM
RabbitX77's Avatar
I am currently installing Aisin Manual Hubs on my 95 4Runner and taking out the ADD. I have read a few treads on here on how to do the procedure and am getting reay to do it tomorrow. Though I have a friend with a 93 4Runner that is all tricked out and did a Taco supercharged engine in his. He is telling me that i have to mess with some vacuum hoses to the front transfer case or my 4WD will not work. I have not read anything about that on this site. Can anyone tell me if this is neccessary and if there are any posts about it! Thank you!
Old Jan 27, 2007 | 12:06 PM
Kyle95sr5's Avatar
Your friend is wrong...
I just installed them on my 4runner. You don't need to mess with any vacuum hoses or anything like that. Just install um, check um, and your ready to roll.
Old Jan 27, 2007 | 12:55 PM
jsnby's Avatar
like kyle said, you don't have to mess with any vacuum lines. just remove the drive flanges, replace with the manual hubs, make sure you tighten everything back up to spec, and you're good to go. Make sure you get a brass drift(mine's 1/2" x 8") to remove the cone washers...they can be a pain the first time you try to remove them.
Old Jan 27, 2007 | 01:30 PM
olharleyman's Avatar
yea i did my last weekend and really all you got to do is pull the endcaps off the axels(gold bearing cap) then the gold bolt and washer put the hubs bottoms on then the gold washer and bolt and cap its that easy I do harleys and i did my hubs in like an hour by myself but had to pull wheels to get the center caps off its really easy no vacume lines at all to mess with.
Old Jan 27, 2007 | 01:44 PM
mt_goat's Avatar
Originally Posted by RabbitX77
... and taking out the ADD...
Sounds like some miscommunication to me. When you say "taking out the ADD" that could mean removing the stock drive flanges or it could mean defeating the whole ADD system. The last of which could involve some messing with the vac lines.
Old Jan 27, 2007 | 02:02 PM
I think you want to leave the a.d.d. hooked up i left my alone just added the hubs and it works fine
Old Jan 27, 2007 | 02:09 PM
Strap22's Avatar
Sponsoring Vendor
Leave the ADD alone and just swap the hubs. It really is that simple.
Old Jan 27, 2007 | 02:37 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
<hijack>
do you not have to get new CVs? someone told me if you do manual hubs on IFS you have to get new, compatible CVs.
</hijack>
Old Jan 27, 2007 | 02:48 PM
mt_goat's Avatar
Originally Posted by drguitarum2005
<hijack>
</hijack>
It was different for the pre-95.5 trucks, you must have a Tacoma right?
Old Jan 27, 2007 | 03:51 PM
RabbitX77's Avatar
Thanks for the help guys! i'll just swap the hubs and leave the ADD alone!
Old Jan 27, 2007 | 03:56 PM
Kyle95sr5's Avatar
You can go ahead and defeat the ADD system to while your at it. This is the very 1st mod I did on my truck the first week I had it. One of my vacuum lines was broke and my 4wd was not engaging so I did this. Took all of an hour and .86 cent plus gear oil and now I don't have to worry about the vacuum system failing me when I need it.
HEre is the article
http://4x4wire.com/toyota/tech/add/
Old Jan 28, 2007 | 06:08 PM
yes, 2000 taco. ive been told both things about my CVs. i still dont know if i can just get manual hubs and install them or if i need to get new CVs at the same time
edit: after a thread i found over at ttora, i DO need new CVs as the ends are apparently different between manual hub and ADD
Old Jan 29, 2007 | 06:10 AM
GV27's Avatar
Make sure you also look at the Yotatech 95.5-2004 Tacomas & 96-2002 4Runners section, drguitarum2005. Not trying to run you out or anything, just pointing out that we're specifically talking about 86-95 trucks in here.
Old Jan 29, 2007 | 06:36 AM
mt_goat's Avatar
Yeah
Old Jan 29, 2007 | 06:49 AM
kmcc78240's Avatar
Question, I thought there was a conversion kit you had to add when switching to manual hubs? Something about the spindle nuts or something. Could anyone clarify.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
KBar
Jul 13, 2015 06:01 PM
Coreyr384
Jul 10, 2015 11:13 AM
ItsJustD
Jul 7, 2015 07:49 AM
