Questions about suspension/tires.... dont hate
Old Apr 10, 2009 | 06:59 AM
CHAUCH's Avatar
Hey guys new owner of a 92 yota pickup. Got a few questions.... I have the notorious saggy rear end, and I want to know what the best way is to get a few inches on the rear.
I have seen 2" blocks, add a leafs and shackle kits available, But I dont know what the best route to go is.
The truck currently has 31" tires that I plan on keeping but switching to a procomp rock crawler 8 hole 15 x 7 3.75" backspace
So the the questions are:
Whats the best way to remedy that saggy rear?
Will the procomp 15 x 7 3.75" backspace work?
Old Apr 10, 2009 | 08:05 AM
PlugItIn's Avatar
search on this, you will find many answers...dont go with blocks, thats a no no...
Edit-OEM replacement leafs will fix your problem, not sure on cost. Im doing that with mine and going to make some bigger shackles myself
Old Apr 10, 2009 | 08:07 AM
Junkers88's Avatar
There really is no best way to fix the rear, a lot depends on what you plan to do with the rig.
Back to stock height? Get OEM replacement springs.
Lift? Lift springs, add a leaf, blocks, shackles, coil conversion.
Lot of options.
Old Apr 10, 2009 | 08:08 AM
DeathCougar's Avatar
Quick check in the appropriate sections yields these results:
https://www.yotatech.com/forums/f116...-guide-155339/
https://www.yotatech.com/forums/f177/
https://www.yotatech.com/forums/f177...thread-169234/
Btw although the first linky is for 4Runners, same concept applies to trucks. Blocks are a nono, add-a-leafs work, as do good leafs.
Old Apr 10, 2009 | 08:19 AM
CHAUCH's Avatar
Thanks for the help guys, If I were to go with an add a leaf on the rear would the toytec work? what are my other options... do I have to get new rear shocks if I just want that 2-3" of lift?
Old Apr 10, 2009 | 08:02 PM
gary96360's Avatar
i like how everyone hates on the block lifts. like every single fullsize pickup has like 3.5-4 inch block stock
Old Apr 10, 2009 | 08:06 PM
iamsuperbleeder's Avatar
lol, the leafs pack on the back of my 91 lay flat when the weight of the truck's on them I compensated for the droop with a set of 3.5" longer shackles from WabFab
Old Apr 10, 2009 | 08:23 PM
gary96360's Avatar
im in the same boat too. today my dad said he had some blocks and ubolts laying around for a yota. i check it out and see that theyre too wide 3 inch. so will longer shackles give better flex than aal? sorry for the thread jack.
Old Apr 10, 2009 | 08:42 PM
874runnersr5's Avatar
Check downey for aftermarket leafs. cheap and good
Old Apr 10, 2009 | 09:09 PM
abecedarian's Avatar
considering we're talking about a light-duty truck, the comparison with full size vehicles is not only inaccurate but completely unwarranted.
Just because an F250 can handle 5" blocks does not mean a 1/2 ton Toyota can.
Old Apr 10, 2009 | 10:32 PM
Matt16's Avatar
Do full sizes come stock with track bars (i have no idea). I imagine they would have to because with blocks and with torquey diesel motors, they'd have VICIOUS axle wrap/ wheel hop without them I'd think.
Also, its not like domestic fullsizes are the pinnacle of automotive engineering...
Old Apr 11, 2009 | 05:31 AM
91diesel's Avatar
I used a cheap quick fix for mine for a house moving and am actually kind of impressed with it. I went to auto zone and got the 'helper' springs. The kind that bolt on under the leaves on just one side of the axle. Anyway, when I jacked the rear of my truck up to put them on, I noticed how much space opened up between the overload leaf and the rest of the pack and put the helper spring in between. The truck rides better than before, can carry a lot more, and is back to stock height + a little. When I first put them in this way it lifted it about 3" (guessing, I never measured it) but now has settled down with just a slight rake you have to look to see.
Old Apr 11, 2009 | 07:25 AM
yoder519's Avatar
chauch heres is a pic of my truck back in the day with teh procomp black steelies 15x8 wtih 3.75 inch backspacing. don thate cuz i whore my yota at any chance i getlol
Old Apr 11, 2009 | 07:42 AM
PlugItIn's Avatar
Axle Wrap explained somewhat You can use blocks, but it is much better to do it right the first time IMO
Old Apr 11, 2009 | 08:53 AM
gary96360's Avatar
i have never seen a stock fullsize with track bars, even the diesels. i used to do many burnouts and never had any problems. yeah there is quite a bit of wheel hop when you start to spin your tires on pavement then it kinda goes away. i bet the few extra leafs (about 8-9 total in the pack) made a huge diff in axle wrap. yeah the mini trucks must get way more axle wrap because of the soft leafs. so hmm shackles or aal. my best bet is probably the procomp 13120 aal. i like how the procomp aal is like 78 bucks on cantire keystone ordering site. probably lordco can order them in cheaper.
Old Apr 11, 2009 | 09:07 AM
CHAUCH's Avatar
Thanks for all of the help guys, I ordered a set of 15 x 7 Procomp blackies. Still trying to decide on what to do with the ass end.
Old Apr 13, 2009 | 01:20 PM
wheatus's Avatar
although not the cheapest solution you could always get a set of air bags. you can adjust them to to the load you are carrying or towing which is oh so nice. plus if you step up to a lift, you can sell them.
Old Apr 13, 2009 | 02:31 PM
PlugItIn's Avatar
Originally Posted by wheatus
although not the cheapest solution you could always get a set or air bags. you can adjust them to to the load you are carrying or towing which is oh so nice. plus if you step up to a lift, you can sell them.
ick...
Old Apr 13, 2009 | 03:28 PM
CHAUCH's Avatar
So I decided to go with the 15 x 8 3.75" backspaced wheels, and probably run a 33" tire
Im trying to decide on the lift now, either going to be a rough country 4" lift
or a toytec 2" bj spacer and add a a leaf.
Im not sure if the toytec kit will allow me to run the 33" tire though.....
Old Apr 13, 2009 | 06:44 PM
gary96360's Avatar
or on the cheap side, just do the bj and a body lift. im planning on doing that to fit 33'or 35's
