Question about toyota rv t case
Old Nov 12, 2019 | 05:08 PM
Warwagon's Avatar
Does anyone know if the t case behind the manual transmission from the toyota RV is gear driven? Theres a guy selling a manual tranny and t case from a Toyota RV with the 22re for 200$ and I'm looking for the ability to do dual t cases since I have an auto. This would be great for a manual swap for me.
Idk what year truck it's from but I can try to find out in the mean time
Old Nov 12, 2019 | 07:26 PM
millball's Avatar
What engine was in the RV and its' build year??
Old Nov 13, 2019 | 05:02 AM
Warwagon's Avatar
The guy got back to me last night and said its out of an 86 with the 22re
Old Nov 13, 2019 | 05:19 AM
millball's Avatar
It's transfer case should be a RF1-A gear drive type. It might be either a forward shift, or a top shift type, depending on the tranny type.
You want a top shift type tranny and case.
Old Nov 13, 2019 | 05:26 AM
Warwagon's Avatar
https://offerup.co/XNtBlxBhA1
This is the ad for it
Old Nov 13, 2019 | 07:48 AM
millball's Avatar
This is a forward shift tranny and t-case. Maybe a G52 tranny???
You can use this stuff for a double case setup, but the rear case still has to be top shift.
I don't know about possible shifter clearancing issues with your tunnel with the different shifter spacing between top shift trannys and forward shift types.
Doesn't look like it has a bellhousing attached
Here's a thread from the Marlin Crawler site>. https://board.marlincrawler.com/index.php?topic=15361.0
Old Nov 14, 2019 | 11:52 AM
Warwagon's Avatar
Thanks man! I'd have to do some cutting and probably fab up a tunnel since I plan on running a drivetrain lift and duals. I figure for 200$ that's not a bad deal.
Old Nov 18, 2019 | 05:32 PM
old87yota's Avatar
Hummm....
I would have liked to see this RV. As far as I have seen there were only a handful of 4WD Toyota RVs made (at least in the U.S.A.)
That RV would have been pretty rare.
Old Nov 18, 2019 | 05:42 PM
millball's Avatar
Originally Posted by old87yota
Hummm....
I saw a 4x4 Sunrader running down I-10 here in AZ just the other day.
Old Nov 19, 2019 | 12:06 PM
old87yota's Avatar
That is pretty darn cool!
KODE
Jul 7, 2010 11:27 AM
YeloSub7
Feb 21, 2010 03:42 PM
sr5yota84
Feb 22, 2009 07:20 AM
Teamsobaco
12
Feb 19, 2005 02:14 PM
