Question about temp guage
Old May 30, 2018 | 02:28 PM
heifetz17's Avatar
Hey guys, my temp gauge is starting to act a little weird, and I'm not sure where to start. When the truck is warming up occasionally the temp gauge will jump to the middle for a while and then fall back down to cold. The gauge does work and reads the correct temp, just jumps sometimes when still cold.
The temp sensor is new OEM, and all other gauges work properly as well. Thanks for any tips!
87 4x4 manual.
Old May 30, 2018 | 03:46 PM
RAD4Runner's Avatar
87 4x4 manual.
And are sure which temp sender correct?
If you are absolutely positively sure and swear by good connections and condition of the gage and circuit.
Search dual-stage or two-stage thermostat.
Old May 30, 2018 | 04:03 PM
akwheeler's Avatar
Just so you realize, as your engine heats up the thermostat is closed, when the coolant in the engine gets hot enough to open the t-stat the coolant in the radiator is still cool/cold. So when the t-stat pops open you get a rush of cool/cold liquid into the engine which closes the t-stat. this will cycle a few times until all of the liquid gets up to normal temperatures.
Old May 30, 2018 | 04:13 PM
RAD4Runner's Avatar
Originally Posted by akwheeler
... this will cycle a few times until all of the liquid gets up to normal temperatures.
Yes. The two-stage t-stat^^^ is what many have successfully used to fix this.
Old May 30, 2018 | 04:20 PM
heifetz17's Avatar
Thanks guys. Maybe I didn't explain very well unless I'm misunderstanding how this system works.
My gauge works properly. The problem I'm trying to solve is first thing in the morning when the coolant is still cold occasionally the gauge will go to the middle, stay there for a second, then fall back to cold. This only happens very occasionally, and never happens once the coolant starts warming up.
I was thinking there was some kind of short or something, possibly in the gauge itself?
akwheeler's Avatar
Yeah, but it isn't really broke either. just annoying to some and confusing to others, after a few minutes all is well.
Old May 30, 2018 | 04:34 PM
heifetz17's Avatar
But would that explain why the gauge goes up when the engine is first started? Perhaps I'm just misunderstanding how this system actually operates.
Old May 30, 2018 | 04:47 PM
wallytoo's Avatar
see the sticky thread about temp gauge repair. one or more connections within the gauge have broken, so the gauge acts as you see. mine did that for five years. now, it jumps to the middle, then pegs to overheat and stays there. i need to solder the wires in the gauge, which are tiny.
Old May 30, 2018 | 04:51 PM
akwheeler's Avatar
does this happen immediately? or does it climb up to half way?
Old May 30, 2018 | 04:55 PM
old87yota's Avatar
I need a little more information here.
How long has this been happening an how long have you owned the truck.
Do you have a "Base / Deluxe" truck with only a speedometer, coolant temperature gauge, and fuel level gauge, OR do you have the "SR5" truck with speedometer, tachometer, oil pressure gauge, coolant temperature gauge, volt meter, and fuel level gauge?
How quick does the gauge jump to the middle after you start it? Can it happen even before you start the truck when the key is in the "ON" position?
What I am trying to find out is if you are observing actual temperature changes (warm to cool, back to warm) as the engine warms up (which I have actually never witnessed on my truck), or if you have an intermittent electrical issue with your temperature gauge circuit.
heifetz17's Avatar
It happens immediately. It's an instant jump from cold to middle and an instant jump back to cold.
I've gone through the repair steps in the temp gauge sticky and there are no broken wires in the gauge. I've inspected the gauge twice now.
I've had the truck about a year but I bought it non running and rebuilt the engine. I've noticed this going on for a couple weeks now. It doesn't happen before the engine is started, but can happen immediately after is started. My cluster does have oil pressure, temp, speed, voltage, etc.
Old May 30, 2018 | 04:56 PM
old87yota's Avatar
I have a hunch that a Dual-Stage thermostat will NOT fix this particular issue.
Old May 30, 2018 | 04:59 PM
old87yota's Avatar
I have a few broken SR5 clusters that did the same thing as your coolant temperature gauge and I could not find any broken wires either, however, I must admit I have not really investigated where the problem(s) lie beyond looking for broken wires.
Old May 30, 2018 | 05:02 PM
wallytoo's Avatar
the other possibility seems to be poor grounds. might be more problematic to solve.
fwiw, my sr5 cluster temp gauge behaved exactly like yours. -15* overnight, start engine, gauge immediately jumps to middle, then after minute or so, drops to cold, then gradually rises to normal.
akwheeler's Avatar
right, moving that quick is not the normal cycling of the t-stat. try cleaning all the threads where the sender screws in as well as the wire terminal, otherwise I would try a different gauge in the cluster if you can find a parts donor.
Old Jun 7, 2018 | 03:45 PM
heifetz17's Avatar
I haven't had much time to dig into this yet, but I was able to get a short video of it happening. I plan to pull the cluster and check the gauge again, and possibly replace it.
This is immediately after starting the engine cold. Hadn't even put my seatbelt on and released the park brake yet.
Old Jun 10, 2018 | 10:30 PM
RAD4Runner's Avatar
... youtu.be...
AAH! Yes, agree. We can see conditions/problems better from the cabin or in front of that engine compartment.
Old Jun 12, 2018 | 04:38 AM
Averette's Avatar
My 1989 Truck was doing the same thing. I took the radiator cap off cold and started the engine. As soon as antifreeze bubbles out I put the cap back on. It was air in the line.
Old Jun 12, 2018 | 05:00 AM
wallytoo's Avatar
not remotely the issue the OP is describing, showing (w/ video), or discussing.
Old Jul 20, 2018 | 07:18 AM
wallytoo's Avatar
bringing this back up for the OP.
based on my recent experience, i do not believe the issue is with the gauge. it is either a wiring issue (broken/cracked/corroded) or a bad ground (sender or harness). i swapped the temp and oil pressure unit from my '87 (with the improperly functioning temp gauge) with the unit from my '88. both are sr5 units, and the units are identical, even though one is from a 4-cyl and the other is from a 6-cyl.
the problem stayed with my '87. both temp gauges work properly with the '88; both function improperly in the '87. therefore, i have confirmred that both gauges work correctly, and the issue is in my '87.
