question about heater not getting hot
My ac doesnt work or my Heater.
Its either my blown head.
Heater core
Or i dont havea thermostat in my truck
lol im guessing on one and 3.
and also my engine is very loud when i rev it up.
is there away to make this very quite?
Heater core
well, if the heater won't blow warm air (considering the dash fan runs) then either the heater core is plugged or the valve that regulates coolant through the heater core is plugged or stuck or the coolant lines back to the water pump are clogged, or the control rod that connects the temp lever to that valve is stuck.
that has little if any influence on the a/c though, if the lever is moved all the way over to cold, so no heat does not mean the problem/cause/solution is the same as no a/c.
but let's go back to the engine... what do you mean the engine is very loud?
and just all around the engine is loud. just all around is loud. revs out really loud not like normally my 22re did or my buddys 3.0 v6 does. got any ideas on how to make it quite?
the1998sr5
15
Jul 14, 2020 08:35 PM
94 Newbie
Aug 6, 2015 10:33 AM
the1998sr5
Jul 16, 2015 06:20 AM
