Pulling a trailer with a 22RE 4Runner...?
Old Dec 19, 2011 | 06:12 AM
  #41
irab88's Avatar
that sounds like a good idea. i remember towing our 23' camper over the rockies, and it was no fun (tow vehicle was an '01 f-150 v8)
Old Dec 19, 2011 | 06:32 AM
  #42
JPL's Avatar
JPL
I wasn't pulling a trailer at the time but when driving between 0 feet elevation and 7K feet elevation I notice a huge power difference. Would this indicate a bad AFM or O2 sensor? Is this normal for the 22RE? What would be a fix for this? I'm guessing my engine is running rich because of the lack of O2 at the higher elevation but I'm not sure (I'll have to pull the plugs).
Old Dec 19, 2011 | 06:38 AM
  #43
irab88's Avatar
yeah, that sounds about right. you need a turbo-normalizer Name:  laughing.gif
you might benefit from an '82 supra afm, if you don't already have one
Old Dec 19, 2011 | 06:42 AM
  #44
JPL's Avatar
JPL
Red face
I was starting to think that was normal. I plan on going with the '82 Supra AFM when I do my cold air intake battery swap mod.
Old Dec 19, 2011 | 06:46 AM
  #45
sided00r's Avatar
I bumped into this Toyota Guide to Towing, has weight capacities per model in part 3, state laws, different hookup education, and even lessons on how to back a boat into the water without wrecking stuff.
http://www.toyota.com/pdfs/towguide_Part1.pdf
http://www.toyota.com/pdfs/towguide_Part2.pdf
http://www.toyota.com/pdfs/towguide_Part3.pdf
Sorry, don't have a clue about oxygen issues.
My truck came with a bumper ball, i'm not sure it can successfully tow a shopping cart...Well...not today for sure...
Old Dec 19, 2011 | 07:03 AM
  #46
irab88's Avatar
i hear this is a good one:
https://www.yotatech.com/forums/f116...e-swap-220884/
Old Dec 24, 2011 | 09:40 AM
  #47
slowpoke's Avatar
i've got a 88 22RE AUTO 4x2 pickup and want to tow my tiny 1500lbs race car on 500lbs single axle trailer. rating on the pickup is 2000lbs. a) can i tow (primarily flats) and california says anything more than 1500lbs needs to have trailer brakes. b) won't trailer brakes on a single axle just pitch the trailer down onto the hitch? i've got 1ton rear springs so pretty stiff in back.
thanks,
Old Dec 24, 2011 | 11:16 AM
  #48
ThatGuy1295's Avatar
Should be just fine with 700lbs
I pulled 5000+
Doug4320
Mar 24, 2018 10:11 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Nickdigg
Jul 7, 2015 06:04 AM
toyota32
Jul 6, 2015 05:42 PM
