pull the + cable and the truck dies, alternator?
trust me, your alternator supplies more than enough power to run your truck. this morning i had to tow start my truck *jump start didnt work* and drove it for 2 hours to grand junction. had my battery tested, and it read 47 CCA when it was supposed to have 177 think it was. 47CCA AFTER 2 hours of highway driving.
got new battery, and no problems since
pull the battery cables off of the alternator while monitoring the voltage...
and just 'cause the alt goes to 18v does not make it an 18v alternator.
It was mentioned above that there's a relationship beween volts and amps- in a nutshell, double the voltage and you only need 1/2 the amps.
Wrong... Think about it... If that was the case, you wouldn't be able to drive long distances without stopping to charge your battery with an external charger. The alternator supplies the running load for the vehicle, and also provides the current to keep the battery charged. The battery is reserve power, and is there to start your vehicle. It also acts as an electrical buffer to prevent voltage spikes. With most newer Toyota alternators, the battery voltage is also required to provide the excitation power to the voltage regulator so that the alternator will actually produce electricity.
A separately excited alternator, which is pretty common, needs that battery to make it all work. hence why a bad battery will still leave you stranded even with a jump start and a good alternator.
And, even more interestingly, most alternators actually produce a 3 phase AC output, which is then rectified to DC and then passed through a voltage regulator, which in it's most simple form, is a zener diode.
Now, my next question is why you cannot see your dash lights?
the charge and brake lights are connected together with a few diodes, that during normal operation of the charge system, blocks current through that circuit. Current from the alternator is trying to push through the diodes, but it can't and won't. But if the alternator or other component of the charging system fails, current from the battery will be able to push through the diodes in the operational direction, illuminating those lights.
This is all based on the fact that under normal operation, output from the alternator will be right around 14V, whereas the battery will be right around 12V, opposing (same polarity connected to each end of the circuit) each other in this particular circuit. The 14V from the alternator cancels the 12V from the battery and hence it maintains a 2V margin over the circuit, more than enough to keep the diodes from allowing current flow (they only require about .7V for a typical silicon diode).
Charging works the same way. Your vehicle will place the alternator and the battery under load, but the battery and alternator are hooked up positive to positive across the load. Here again, the source with a larger voltage, providing the load is not outside of the capabilities of the two sources, will be the one pushing the current through the load AND charging or attempting to charge the source with less voltage. GSGALLANT is absolutely correct in saying the alternator provides virtually all the load current, and the battery is simply charging, or used for reserve capacity.
I can explain a lot more, if anyone is curious...
#26
Ok i see where I faulted in my statement, i would regularly jump start vehicles at work, every once in awhile i would get a car with a battery so dead that the car would not run and the alternator was charging just fine. does that have something to do with the alt. not being excited because the battery is to dead? please explain this phenomenon to me.
#27
#28
glad you figured it out haha. And what I said can be confusing if you aren't strong on your electrical skills. sorry for the confusion.
the1998sr5
Oct 19, 2016 12:48 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
