Pull 3vze with r without transmission?
Pull 3vze with or without transmission?
I need to pull my engine, but I am not planning on doing any work on the transmission. What is easier, pulling it with the transmission attached or disconnecting the two before I take the engine out? I figure the two main points are weight and manouverability when pulling it out vs. getting to all the bolts that hold them together when they are still on the car.
Any thoughts or experiences?
I have a friend at work, if he's doing work on the engine, he pulls the intake, then the heads with exhaust. Once you get that out the bellhousing bolts are right there.
He's done more headgaskets on the 3.0 than I care to mention. They were recalls, not his truck.
I would take the engine out by itself... it is a little tricky to get the tranny out with the engine without a body lift on but if you have a couple of people to help it isn't so bad. The 5 speed is easier than the auto though...
Standard? you have to slide motor forward till you disengage the tranny from the clutch.....
Im pulling a motor but i cant get the motor out. its getting hung up somewhere in the tranny. I have unbolted all the bolts on the bellhousing that go to the block but stilll no luck. Any suggestions?
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
Poncho0206
Jul 10, 2015 06:21 PM
Hey, it's almost the british version of the word
