PS Leak
Old Feb 26, 2008 | 03:09 PM
jason191918's Avatar
PS Leak
My PS pump is leaking from behind the pump. Should I just replace the O-Ring or should I do the seal as well?
Old Feb 26, 2008 | 03:11 PM
Paul H.'s Avatar
I would do it all.
Old Feb 26, 2008 | 03:16 PM
I am trying to avoid removing the pump, as I need the truck on a daily basis. Also, I do not want to get over my head rebuilding the entire pump.
Old Feb 26, 2008 | 05:49 PM
87toy.'s Avatar
just get some of that make a gasket stuff and goop it on there!! lol Not.
http://www.trademotion.com/partlocat...92&catalogid=1
they also have your pump, and hoses, but the pump is 350
Old Feb 27, 2008 | 03:30 AM
That presents a problem...
Old Feb 27, 2008 | 04:59 AM
dirtoyboy's Avatar
I would just swap a good dry box in....much quicker and easier than rebuilding. A complete rebuild kit (which is what you should get if you are going through all of the trouble) is around 60 or 70 bucks I think. Rebuilding a box is not that hard....but its not the easiest thing either... Dry boxes go for around 100 bucks all day long
Old Feb 27, 2008 | 05:25 AM
Brenjen's Avatar
I had a whole post typed out & lost it when I went to find & copy the link lol
I just rebuilt mine for the cost of a $33 kit shipped to my door (Edit:that's $24.26 for the kit & $8.99 shipping). Either way you go rebuild or swap out; you'll have to take it out of the truck. You can't really swap out seals or O-rings with it still in the truck. You'll end up causing more problems than if you just took it out.
My advice is rebuild it for $30, it took me three hours start to finish including a trip to the parts store for a new, slightly shorter belt. Unless that extra $70 - $100 isn't an issue then, go ahead and swap it out for a used one & rebuild your old one while you have it out....but you'll kick yourself for not rebuilding it. It's simple.
http://members.cox.net/stacewilliams/ps-pump.htm
Old Feb 27, 2008 | 05:47 AM
dirtoyboy's Avatar
DOH! my bad....i thought we were talking about the steering box ...not the pump!
I have good steering pumps used if you want one.... they are around 40 to 50 bucks SHIPPED.
Old Feb 27, 2008 | 10:13 AM
tibbycruiser's Avatar
Throw some powersteering fluid with stop leak in there and it will stop the leak.
Old Feb 27, 2008 | 12:02 PM
tc's Avatar
tc
Until it eats the seals. Our systems take ATF not power steering fluid!
PSF means a quick and certain death for your PS pump. If you have done that, don't try to rebuild - get a replacement. Before taking the old one off, be sure to completely flush the system.
http://personal.utulsa.edu/~nathan-b...10onvehicl.pdf
Yes, in my experience, using power steering fluid instead of ATF IS that big a deal.
Old Feb 28, 2008 | 06:15 PM
Maybe thats why mine leaks...
I ordered a reman today. Gonne flush the whole system and use atf from now on. thanks TC
Old Feb 29, 2008 | 04:13 AM
Brenjen's Avatar
A rebuild for $30 would have been a helluva lot cheaper & it probably would've taken about the same length of time for the kit to arrive. I think I got mine in two days. But to each his own, if you didn't feel confident taking one apart you made the right call....& TC is dead on; never never never use power steering fluid. My wife proved that point to me.
Old Mar 7, 2008 | 11:19 PM
So I started to change out pumps tonight. I got all the lines and bolts out, but the pulley is not off yet. I actually searched and got a few hints as to how to remove the pulley, but that's a job for tomorrow. My only question at this point is, is there a right and wrong way for the vacuum lines?
Old Mar 8, 2008 | 04:00 AM
Brenjen's Avatar
Those vacuum lines aren't even essential; heck I broke one of the darned plastic nipples when I was putting the rebuilt pump back in my 4Runner. I just plugged them off, it's for the idle up when the pump is at full steer, I never leave my pump at full steer for more than a second & then only so I can see how much I have left & back out of it (if that makes sense) so I don't miss it.
As far as I know they are location specific but it shouldn't be hard to swap if you get it backwards.
Old Mar 8, 2008 | 06:42 AM
Thank you for the response.
he's gone
7
Dec 3, 2019 07:08 AM
4runnerjunk
Aug 22, 2015 09:06 AM
accuracy
Aug 4, 2015 08:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
