Problem with my truck
vacuum leaks.
i just ask, to be thorough. seems like youve been through the whole engine, but what else could it be.
all you need is air, spark, fuel. you have all that.
power needs everything to be flawless (or at least operational)
#25
have you tested your fpr (fuel pressure regulator) for its psi.
could be a broken diaphragm or bad injectors, seals, pintles-flow.
photo your spark plugs for us.
#26
I must check it!! i didn't check this one!
stormin94 I live in Poland... so this is where i got my LPG.
For this engine you must find LPG instalation with injectors of gas.
There are several German producers who make very good LPG instalations.
#27
again :(
got it :p I have changed distributor, and problem was timing!!!!
It works almost excelent, almost because of one litle thing...
Idling is going up and down, when its cold you feel it very hard , it goes from 900 to 500rpm! when its hot you dont feel it so much betwen 900 nad 880rpm. Any ideas? please help... is it TPS?
GreenLion
Jun 7, 2021 10:49 AM
duckhead
170
Nov 13, 2017 06:07 AM
bigblue82
10
Jul 6, 2015 08:27 AM
bowhunter1640
18
Jul 5, 2015 03:30 PM
nrgetic99
Jul 23, 2002 04:42 AM
