Problem: Hard to shift gears.
Old Jun 4, 2010 | 10:03 PM
  #101
Mazzola's Avatar
I bought a bleeding kit for 10 bucks and it worked I saw no more air being pumped. But the clutch is loose again. I feel like I'm gonna have to repace the hydrolicnline and slave cylinder too. When we originally replaced the clutch was stiff and seemed to work but became loose again. If It doesn't work after replacing those too I'm giving up and calling a mechanic.
Old Jun 5, 2010 | 05:07 AM
  #102
myyota85's Avatar
just make sure there is no air left
Old Jun 5, 2010 | 06:44 AM
  #103
YotaWoRx's Avatar
have a buddy push on the clutch pedal while you simultaneously check the operation of the slave. when the clutch pedal is pressed, the slave should operate fully.
Old Jun 5, 2010 | 07:13 AM
  #104
Mazzola's Avatar
The clutch has no pressure. I think I need to bleed it again. I think the line is bad and lost the fluid.
Old Jun 5, 2010 | 08:43 AM
  #105
yayfortrees's Avatar
Yeah, just take it to a shop.
Old Jun 5, 2010 | 11:31 AM
  #106
Mazzola's Avatar
I know someone who will do it for 50 but I want the satifaction of doing it myself.
Old Jun 5, 2010 | 11:48 AM
  #107
Mazzola's Avatar
Here's the bench bleed.
Cody (BackGateYota92) hooking the new master up to my clutch petal because he could fit under my dash better then me.
The new master cylinder installed.
Tommorow or tonight if Cody ever calls me back I'm gonna bleed the whole system and see if that fixes it. If not I'm just gonna cry and have to go back to driving the jeep until I can get someone to fix it.
Old Jun 5, 2010 | 03:10 PM
  #108
Mazzola's Avatar
I have this slave cylinder too should I replace it also you think?
Old Jun 5, 2010 | 04:47 PM
  #109
myyota85's Avatar
might as well i just replaced my clutch and no workie so i changed both the cylinders and bled for hours and never could build up pressure then i rented the suction tool and that peddle is great now.
Old Jun 5, 2010 | 05:13 PM
  #110
Lumpy's Avatar
For all they cost replace it as well.
Old Jun 5, 2010 | 05:36 PM
  #111
Mazzola's Avatar
I got a slave for free an I think I'm gonna look into that suction tool.
Old Jun 6, 2010 | 06:29 AM
  #112
myyota85's Avatar
what took 2.5 guys 2-3 hours took me 10 mins with this tool. i rented mine from advance auto. its litterally free, just a deposit but u get that back.
Attached Thumbnails Problem: Hard to shift gears.-dsc00102.jpg
Old Jun 7, 2010 | 04:30 PM
  #113
Mazzola's Avatar
Disconnected the line, cleared it. Installed the slave and found the bolt on the bell housing is stripped. So I'm done for the day and am going to have to figure it out tommorow. But I got a suction tool and it works really good.
Old Jun 7, 2010 | 05:02 PM
  #114
myyota85's Avatar
sorry to hear about that bolt got a tap? glad to hear u grabbed the suction.
Old Jun 7, 2010 | 10:17 PM
  #115
Mazzola's Avatar
Getting one tomorrow from a friend.
Old Jun 8, 2010 | 12:01 PM
  #116
myyota85's Avatar
take it nice and slow good luck.
Old Jun 8, 2010 | 01:35 PM
  #117
93yota93lude's Avatar
i think i remember you saying you replaced the clutch a little while ago right? in my prelude i went with a cheap clutch for quick fix a few years back before i knew anything about cars or trucks but like 4 months after the install same thing happend i was replacing all the parts and bleeding but turned out the pressure plate from the clutch kit was bad and had a few broken fingers on it... but dont wana see you pull it out and not be that so just make sure you double check every other possibility before pullin it...
Old Jun 8, 2010 | 06:53 PM
  #118
Mazzola's Avatar
No I got a heavy duty napa brand clutch. My friends a mechanic and it's the one he recomended. Also I got the Heli-coil kit today, but the drill bit was too long and the frame kept getting in the way so I need to trim it down tommorow. God this is taking forever. I feel like 92 TOY, except I don't have a pimp wagon to drive while fixing the Yota.
My personal hell the past week and a half.
Old Jun 10, 2010 | 08:24 PM
  #119
Mazzola's Avatar
She runs! And shifts like new! I'm still gonna get a new pilot bearing to imrove it even more. But I got my DD back for now.
Thanks everyone for all your help.
Old Jun 11, 2010 | 05:06 AM
  #120
Lumpy's Avatar
Good to hear!!!
