Preference for O2 Sensor Brand?
Old Jun 8, 2006 | 04:07 AM
TNRabbit's Avatar
Question Preference for O2 Sensor Brand?
Does anyone have suggestions for the best brand of o2 sensor? NGK or Denso? What are your experiences with each?
Old Jun 8, 2006 | 05:12 AM
rentedmule's Avatar
NGK worked well for me. It's the only brand I've used on the yota so I can't really give an opinion on others.
Old Jun 8, 2006 | 05:27 AM
regularguy412's Avatar
Either NGK or Denso is fine. Try to avoid Bosch or any of the generics.
Mike in Ar
Old Jun 8, 2006 | 05:40 AM
91_4x4runner's Avatar
I have a Bosch and it has worked for the past err... 80 miles? I haven't been driving my 4R for the past few days. I would've gone with an OEM one, but I didn't have input on the buy, my dad did. Why does everyone seem to avoid Bosch like a plague?
Old Jun 8, 2006 | 06:16 AM
kyle_22r's Avatar
i personally think bosch stuff is low quality compared to denso or NGK. their plugs always seem to fould up, can't vouch for their O2 sensors.
Old Jun 8, 2006 | 07:45 AM
97Limited's Avatar
NGK works good for me too!
Old Jun 8, 2006 | 12:39 PM
LS1Steve's Avatar
wheres a good place online to get both sensors cheap??
Old Jun 8, 2006 | 01:18 PM
Elton's Avatar
for your 4runner
denso $68 http://www.sparkplugs.com/more_info....72327&pid=1968
ngk $38 http://www.sparkplugs.com/more_info....72327&pid=3992
Old Jun 8, 2006 | 05:34 PM
LS1Steve's Avatar
awesome, thanks!
so are the front and back ones the same?? i just buy two of these?? its been 215k miles, i figure its about time to replace, my mileage is about 11
Old Jun 8, 2006 | 07:15 PM
TNRabbit's Avatar
Originally Posted by LS1Steve
awesome, thanks!
You need to look underneath and see if yours is in front or behind the catalytic converter. You only need one.
Old Jun 8, 2006 | 10:15 PM
midiwall's Avatar
Originally Posted by TNRabbit
You only need one.
...and if there're two, then that's the front one.
Old Jun 8, 2006 | 11:29 PM
humanoid's Avatar
How easy is it to change these things on a Taco? Bolt off bolt on?
Old Jun 9, 2006 | 05:14 AM
midiwall's Avatar
Yeup. Should take about 10 minutes including the time to get out your tools.
Old Jun 9, 2006 | 03:10 PM
Elton's Avatar
thats if you can break the bolts lose
Old Jun 9, 2006 | 09:10 PM
humanoid's Avatar
Some good penetrant the night before on the bolts should do the job, no?
Old Jun 9, 2006 | 09:19 PM
midiwall's Avatar
PM Blaster will help, but a lot depends on the age and the "home" of the truck. Mine spent it's first 5 years going through Chicago winters. When it finally came time to do the O2 sensor, it was an interesting experience.
Soak the studs & nuts in PB Blaster, wait an hour, give it a shot. Repeate as required.
BE CAREFUL - you can EASILY snap those studs off. If you do, then it's a trip to an exhaust shop to get it dealt with.
Old Jun 10, 2006 | 07:40 AM
chugs's Avatar
Has anyone tried gettin' their 02 sensor replaced for free from dealer? It says it in the owners manual that u can get it replaced for free, parts and labor...i think it's on page 156 in owners manual..
Old Jun 10, 2006 | 07:45 AM
HUTCHSTACO's Avatar
what year maual says that?
Old Jun 10, 2006 | 07:52 AM
chugs's Avatar
i have a 1994 toyota pickup 4wd
Old Jun 10, 2006 | 07:55 AM
midiwall's Avatar
There are a couple of threads about this here... you should try searching.
Basically there's a mileage limit on that concept of "free". Call the service dept first before you go in.
edit: searching on "o2 free" turns up:
https://www.yotatech.com/forums/f116/free-o2-sensor-replacment-83724/
There are other discussions as well... Searching's cool. Searching's neat. Searching's the place to be.
