Power window issues
Old Apr 30, 2010 | 09:21 PM
trevorwms's Avatar
Power window issues
So, I'm driving an 89 4Runner and my front windows all of a sudden just stopped working. I know it's the relay that's the problem, because I'm not getting any power to the switch and I've checked all of the fuses. I also rebuilt the switch and cleaned all of the connections inside.
What I'm curious about is can I just bypass the relay with power directly from the battery? I know a relay is supposed to control power from a higher power source to a something that uses less power, but I'm wondering if the difference in power between the battery and the power window motor is such that I could bypass the relay and not fry the motor.
Any help on this issue would be great, thanks.
Old Apr 30, 2010 | 10:03 PM
yayfortrees's Avatar
Usually, a relay is used to close a circuit with a lot of current, instead of running that current through the switch. The most well known is a starter relay. If it wasn't for the starter relay, you would have that huge 2 or 4 gauge wire running up to your ignition, and then to the starter.
I realize a window motor doesn't pull anywhere near as much current as a starter, but my guess is that the switches aren't made for it. It might work for a short while, but the switch will likely burn out much quicker than it should.
Just replace the relay, it's there for good reason.
Welcome to YT!
Old Apr 30, 2010 | 10:32 PM
trevorwms's Avatar
Alright. Thanks.
Old Jan 17, 2011 | 04:01 PM
Blue_petersen77's Avatar
i just had a similar problem. turned out the harness plug right next to the kick panel fuse box had come loose. popped it back in and all the windows work perfectly again.
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
