power steering pump
Old Aug 25, 2008 | 01:48 PM
hmmwv15's Avatar
Originally Posted by Jay351
Mine was leaking really bad, (ATF is very flamable) it eventually just fell apart (pulley went into the rad). A used toyota pump is around 30-40 bucks. Way better then any aftermarket unit aswell.
That explains why my alternator caught on fire...
Now I'm really worried about it leaking. I guess I'll just keep my fire extinguisher handy and pray that I'll make it the 2 hours that it's going to take to get down to river rock. Looks like I'll be installing the new one first thing after all.
Old Aug 25, 2008 | 01:58 PM
YOTABP's Avatar
get an original toyota part, used or new. Advanced and Autozone are decent but some of their rebuilt crap isn't worth jack . I bought a clutch master cylinder and it turned out to be bad, then i got another one and it wasn't working good. Got one from toyota and ya it was more expensive, but I haven't had a problem with it at all. Toyota parts rape
Old Aug 26, 2008 | 10:12 AM
hmmwv15's Avatar
I went through 3 master cylinders from autozone, finally got one from advance and it worked. I usually hop parts stores, normally just advance abd o reillys, only time I'm ever in autozone anymore is to exchange alternators from a lifetime warranty from 15 years ago.
Old Aug 26, 2008 | 11:07 AM
Ardent's Avatar
Agreed. However, local Toyota stealership around here wanted $450 for a new PS pump. Dirtoyboy is shipping me a used one...
Old Aug 26, 2008 | 12:54 PM
  #25
BoostinChick's Avatar
I paid $70 for one from Advanced Auto, I love that place! If also comes with a limited lifetime warranty, so pretty much if it goes I just yank it out bash it on the ground a couple times, I get a new one.
Advanced Auto is the shizzle only place I know that has a warranty on their brakes too. I get a free 1 time replacement once they wear.
Old Aug 26, 2008 | 02:34 PM
  #26
hmmwv15's Avatar
Bolts were tight as a drum.
And now that it's getting closer to the wheeling trip, my brakes are acting up again. I have no clue why, they have been good since I fixed them last. Now they are acting like there is air in the lines. Only thing I can figure is that I didn't bleed them enough when I removed/installed my rear diff. (Brakes have always hated me)
Old Aug 26, 2008 | 03:05 PM
  #27
abecedarian's Avatar
did you bleed the lspv too?
Old Aug 26, 2008 | 04:45 PM
  #28
hmmwv15's Avatar
Yup, I've just never had any luck with brakes. Always takes me longer than it should to get them to work 1/2 way decent. I'll get someone to help me bleed them tomorrow.
Old Aug 26, 2008 | 05:05 PM
  #29
tc's Avatar
tc
Sounds like an operator technique problem ...
Start with the PS rear, then DS rear, then PS front, then DS front, then LSPV.
http://personal.utulsa.edu/~nathan-b.../3checksan.pdf
Old Aug 26, 2008 | 05:21 PM
  #30
and I'd suggest not just a 'bleed' but a full flush of fluid.
Old Aug 26, 2008 | 05:53 PM
  #31
hmmwv15's Avatar
I have flushed the system twice since I owned the truck. Once when I had to do a complete brake job (rebuilding calipers, etc.)
I thought you bled it like this though:
1. Driver side rear (farthest from MC)
2. lspv
3. pass. side rear
4. pass. side front
5. driver side front
Basically I was taught to bleed first what is farthest away from the master cylinder.
Old Aug 26, 2008 | 08:39 PM
  #32
tc's Avatar
tc
You are correct about going furthest to nearest - the FSM says LSPV last though. At least after the passenger side rear, though - I bet you are getting bubbles trapped in between there. The brake lines both come to the LSPV then to each side...
Old Aug 26, 2008 | 08:51 PM
  #33
looking at the brake circuits, and considering the unwritten rule about starting furthest and working to the closest, I'd do passenger rear, driver rear, LPSV, passenger front, driver front. But I would want to see CLEAN fluid at each bleeder.
Old Aug 27, 2008 | 10:19 AM
  #34
hmmwv15's Avatar
If you look at the brake lines it is a longer distance to the driver rear than passenger rear.
I'll have to try the lspv last this time. There IS clean fluid in the system.
Doug4320
Mar 24, 2018 10:11 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jonny246
Jul 12, 2015 04:51 AM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
