Power steering leak from rack?
Old Apr 1, 2021 | 02:59 PM
joestox's Avatar
Hey all, I've got a 2nd gen 1994 4runner A/T 4WD.
I've also got a slow power steering fluid leak that appears to be coming from some kind of threaded bolt(?) on the power steering rack(?). I could be wrong about what this bar going between the two front wheels is. Is this the power steering rack? What is this bolt?
I cleaned the area and have been monitoring for the leak over the past few days and it doesn't seem like the fluid is dripping from above, just slowly leaking out of this threaded thing. Its on the front passenger side of the car.
Can anyone shed some light on what is happening here?
Old Apr 2, 2021 | 09:44 AM
fdp101452's Avatar
you talking about the castle nut? There's no fluid in that rod. Leaking above and running down.
Old Apr 2, 2021 | 11:18 AM
joestox's Avatar
ah you;re right - I put a piece of tape on top of the castle nut last night an yeah there was fluid on top of it this AM oops!
Old Apr 2, 2021 | 11:41 AM
RAD4Runner's Avatar
Yes, leak coming from above.
Original Poster is in the best position to look for that leak.
Old Apr 3, 2021 | 03:53 PM
az4x4runner's Avatar
That metal bar is called the relay rod. The 4runner didn't get rack & pinion steering until 1996. However, that location is a common spot to find fluid (ATF) dripping down from the power steering pump on the 3VZE powered 4runners. Is that what you have? Maybe have a look at the back/bottom of the PS pump.
swobo_yota
May 11, 2018 05:57 PM
DetroitStyle
Sep 24, 2012 11:33 AM
SleevelessSteve
11
Aug 26, 2009 11:52 AM
directlink
Oct 20, 2007 09:10 PM
Montana T4R
Nov 4, 2005 06:29 PM
