Power Steering Fluid Resevoir O-Ring Photos
Old May 16, 2006 | 06:14 PM
Snorkeldepth's Avatar
Smile Power Steering Fluid Resevoir O-Ring Photo
Well, I broke down and finally replaced that leaking old o-ring. I had bought the whole rebuild kit. But, thanks to YT I decided to forego the total rebuild for now. My power steering works fine. The darn pump has just been leaking all over the place for a while. So, I sucked the fluid out of the resevoir, disconnected everything, and removed the pump. It was a nasty job cleaning off all the grime. I removed the tank and the o-ring. I thought you all might appreciate what a new o-ring looks like next to a leaky old one. So, here they are . .
I put everything back together and let it run for a while. No leaking so far. Let's hope for the best! Thanks again YT . . . I couldn't do all this stuff without all of you. If I recall correctly I owe a special thanks to Mt Goat.
Old May 16, 2006 | 06:18 PM
waskillywabbit's Avatar
There are several O-rings on the pump that need to be replaced besides the one you show...mine was leaking several places and once I replaced the "non-reusable" O-rings, no more leaks.
The thing about it is that they all look the same, new and old, so if you take the pump out, replace them all while you are at it.
Old May 16, 2006 | 06:32 PM
Oops, that's right . . . . the Wabbit helped out too! Thanks!
I only saw two o-rings that are "external". The pressure port union o-ring and the resevoir o-ring. The rest are in the guts of the pump. I was trying to avoid tearing the pump completely apart. Here's the schematic I'm relying on
http://personal.utulsa.edu/~nathan-b...11powerste.pdf See page SR-47
Thanks again! (Doesn't that o-ring on the right look all skinny and emaciated next to that plump, healthy o-ring on the left?)
Old May 16, 2006 | 06:46 PM
Yeah, those two are the most common culprits...I learned that lesson the cost of a new pump...instead of some O-rings, but at least I could take back the core...so now I know I have a new pump and fresh O-rings all around...just waiting to take my core back after I finish my hydro assist...as my drilled out restrictor plate is in the "old" pump until I add the ram...but I digress.
I got fab work to do....
keithporter83
Jul 24, 2015 07:37 AM
itzmywife's
Jul 23, 2015 08:32 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
voiddweller
Jul 15, 2015 03:56 PM
jon.r
Jul 11, 2015 03:34 PM
