power loss, no acceleration problem, any help would be good.
Old Feb 2, 2015 | 01:49 PM
skypilot's Avatar
Originally Posted by joehill
its in the shop now. its been there since friday and I hope they find the problem tomorrow. if not i may need to junk it. which i dont want to do at all because i love that truck and I cant afford a new car.
Its definately savable. I have had symptoms like this from a failed distributor coil. Rich-porter to the rescue.
I cases like this I like to use alot of injector cleaner in the gas. I good oil change and a full tune up. Its usally something stupid since these are very simple engines.
Old Sep 14, 2016 | 06:03 PM
Toy4byfun's Avatar
Has the problem been resolved? If so what was it?
Old Sep 14, 2016 | 06:06 PM
Toy4byfun's Avatar
Originally Posted by Hippiefromhell
i have a 2000 toyota 4runner with a 2002 motor in it and i have been having problems with the idle and now i can't even move the truck it just sputters when i put into gear and try to accelerate. i have fixed the idle issue but i was driving to work this morning and it just start to sputter going up a hill and would not even accelerate at all. i had to limp back home at 5mph. i could barely touch the throttle and then it would cut back out. here is a list of what i have done to the truck to remedy some of the issues.
-clean mass airflow sensor and test
-clean throttle body
-clean idle air control valve
-new plugs and wires
-new fuel filter
-checked catalytic convertor and i can see light through it so i guess thats good
-i unplugged my o2 sensor on downstream and it didn't make a difference
-checked all fuses
i don't know what to do next i bought new oxygen sensors but i don't know if i need them or not i think i need the down stream one but the up stream one looked ok from the outside.
i am at wits end i am about ready to burn this truck to the ground so please help someone.
Old Sep 16, 2016 | 07:56 AM
Huntinman13's Avatar
Yes i have 93 4runner battery acid went all over my motor and when i start it and drive i have no power i need help plese respond
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
