PLZZ help ASAP engine light flashing idle problem
Old Aug 4, 2010 | 03:49 AM
  #41
93yota93lude's Avatar
ok so i got a multimeter and i have a buddy who owns a junk yard and he just go a 94 4runner in but its auto matic so i dont think the ECU will work out of it but im going to check my EFI relay and do all the tests i need to to find out if thats bad caz im sure those would be the same right?
Old Aug 4, 2010 | 07:31 AM
  #42
thook's Avatar
Yes, the relay should be the same.
http://personal.utulsa.edu/~nathan-b...95efimainr.pdf
Old Aug 4, 2010 | 10:04 AM
  #43
OK. thank you so much i will get straight on testing the relay tonight and i will let you guys know either tonight or tomorrow morning how things went my laptop is still down so might have to give feed back when i get back to work tomorrow..
Old Aug 4, 2010 | 08:53 PM
  #44
thook's Avatar
Cool beans! Good luck......
Old Aug 5, 2010 | 05:17 AM
  #45
ok so i texted the relay power going to it when i turn the key no power leaving so im going to replace that today and hope that fixes it...
Old Aug 6, 2010 | 01:39 PM
  #46
ok update..... replaced the relay still nothing not starting up.... and still no codes so you think ECU next?? i got a buddy who can get a used one for 120 that came out of a tottaled truck so ugh just sucks anything else you guys can think of for me to test???>>
Old Aug 6, 2010 | 08:45 PM
  #47
thook's Avatar
Yeah, you'll need to verify power's getting to the ECU from the relay. Does the CEL illuminate when you turn the key to ignition?
Old Aug 8, 2010 | 06:49 AM
  #48
yea the CEL does light up but it just stays on even with the jumper wire in E1 and TE1 no flashes still do i need to check for power at the ECU where is that located passenger floor?
Old Aug 9, 2010 | 04:50 AM
  #49
ok so i just found out a friend of a friend owns a junk yard and just got in a rolled pickup year 94 3.0 5 speed. mine is a 93 but still should be the same right? no water damage so the ecu didnt get wet he will give me for 100 bucks? think i should just buy it and put it in caz its so cheap?
Old Aug 9, 2010 | 09:13 AM
  #50
thook's Avatar
No.....need to check for power. It's getting there. But, the CEL should flash even a "no trouble" code when you have the terminals jumped. Get the ECU.
Old Aug 9, 2010 | 09:18 AM
  #51
ok ill try jumpin it again later tonight.. does automatic to manual ECU matter it has to be manual on correct..
Old Aug 9, 2010 | 09:24 AM
  #52
thook's Avatar
No need to do that, though, right? I mean you said already that the CEL didn't flash with the test terminals jumped, right?
An auto ECU will work. But, you have to short the P/N safety switch circuit and do some other things to keep the CEL off. I'll have to reply more on that later. Gotta run...
Old Aug 10, 2010 | 11:47 AM
  #53
ok thank you!! my buddy just blew his head gasket and he is going to pull his ecu out for me so i can put it in mine and if it works then buying one friday.. but just to be clear the problems i was having with the rough idle and smelling gas and felt like it was missin that could be solved with an ecu? (if the ecu is the problem)
Old Aug 10, 2010 | 06:19 PM
  #54
thook's Avatar
Well, if the ECU is the problem, then certainly. And, of course, it's possible there's more than one thing going on. But, if the ECU's bad, you could replace everything with the entire engine and it still won't run right. The ECU controls everything electronically in regards to fuel management. Well, most everything.
You know I wanted so bad to answer that question with something sarcastic, but today's your lucky day. It's just been to hot to be a smartass.....
Old Aug 10, 2010 | 06:25 PM
  #55
hahahah well thank you i appreciate that i just got home from the beach got my ski all cleaned up and now just waiting on my buddy to call me to meet up so i can grab that ECU from him i hope this is all that i need............ sucks having two vehicles and neither run haha
Old Aug 10, 2010 | 06:59 PM
  #56
thook's Avatar
Ooooo......I know that one. Good luck, chuck!
Old Aug 12, 2010 | 04:33 AM
  #57
ok GREAT news put the ECU in last night it turned over for a while then stumbled to fire so i tried it a few more time if started but a little rough and smelled like gas really bad and then slowly idled up to the normal idle and cleared up i let it run for about 45 min just idling to make sure it was good and to charge battery and to make sure it would over heat or anything then i drove it around for about 3 hours and its been running great drove it to work this morning everything just fine now need to buy an ECU and return his so freakin happy!!!! thanks for all your patients and help!!
sonic concepts
Aug 16, 2025 03:13 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
Skydigger
Jul 1, 2002 12:39 PM
