Pittman/ Idler arm needs replacement
if you have to use ball joint spacers to get your camber corrected then there is something bent under there and you should really get it fixed. There is no reason why you have to add anything to these truck to fix the camber. The OEM adjusters should work fine as long as you don't have your torsion bars cranked. If you don't know if they are or are not or what they are, chances are they are not cranked.
Camber problems are typically caused by worn ball joints or the combination of ball joint spacers and cranked torsion bars. There is a ton of info/pics on here if you don't know what ball joints are. The less likely but certainly possible issue would be bent parts.
Hello. i am new to this forum. im not sure if i should be posting here but this is my problem: i have an 86 4runner, just bought it. the camber is off in both the front tires (negative camber). i took it for an alignment thinking that was what i needed, the dbag gave me some run around about how he couldnt do it but also suggested that i replace the idler's. since i knew the bearing was loose in the front right, i replaced it; this fixed some of the camber problem but it is still off. so i guess my question is, will replacing teh idler arms fix me up?
take a measurement from the center of the hubs to the bottom of the fenders on the front end. this will help figure out the position of your torsion bars. if someone has loosened up your t-bars, then it could possibly cause negative camber since loosening them pulls the top of the tire inward, lowers the front end and softens the ride. they would have had to loosen them up considerably to not be able to align the camber, and the front end would be very soft and probably hit the compression bump stops quite often. cranking them would push the top of the tire away from the truck, thus giving positive camber, added height and a stiffer ride. most people don't touch them unless necessary, but don't rule it out until you take some measurements.
another good measurement to take is to measure the distance between your lower control arms - it should be somewhere in the 16-17" range. any wider than maybe 17" would mean that they have spread apart most likely due to someone jumping the truck and a hard landing. this is why there are aftermarket IFS braces/LCA truss available for our rigs. my guess is that this is your issue.
check all ball joints for wear as well. worn upper BJs could be the problem too.
i would definitely start by taking those measurements and seeing if your suspension is within spec. if not, then you need to think of solutions to getting those wheels vertical again. BJ spacers will give positive camber after installed, so they COULD help get within spec, but like xxxtreme22r stated - it'll get you there, but something's bent if you NEED them. if your LCAs are in fact spread apart, then you'll have to address that. i dunno how, but I doubt some bar clamps would pull it together with enough force. maybe someone else has better suggestions on what to look at, but those are where i'd start.
#25
If anything ball joint spacers make it more difficult to set the camber correctly, hence the question. I wasn't implying that they would correct his camber problem. Anyway...
#26
TURBOrunnerNM
Jul 22, 2015 11:01 AM
