Pics of 33's, spacers, clearance, etc...
I was thinking "why is he posting clearance pics from 10 feet away where you can't see much of anything?"
I might have missed it but are all those pics with bj spacers?
Looks good Frank...
I've been running my 33x12.5" Durango MT's like this for a little over 1 years now with Zero issues... (other than they do rub a little bit) I've got a 2" body lift to go in, as well as a 4" suspension lift. So That'll fix my clearance issues, and create 2 more on the spindles - so then 1" wheel spacers go on...
No need to worry. Like I have said NO issues.....
The only potential issue could odd wear but as you can see from 91 4Runner they are wearing well.
Frank
#25
That worked on my Samurai but the 4Runners are a little heavier.
#26
I'm going to run it up on my ramps today and see what's up. I'll take some pics of what I trimmed and all.
I'll probably add this all to the website too so it will be here and there for future use.
Frank
Frank
#28
In my case it's welcome back. I had the same size on my 89's with a 4" bracket kit and 1.5" spacers. I like the lower look myself and also find it much more functional. The taller the vehicle the less the IFS flexes.
Frank
Frank
#30
Any issues with the inside of the rear tire rubbing the frame under full stuff. I just put some 12.5's on a set of stockers on my truck. I went and drove over some rocks and I am getting awefully close to the frame with the rears, and I'm not at full stuff yet.
I think I may have to get some 4 or 3.75 BS rims. I had no problems with the 3.75" steelies that I was using b4. Too bad I really like the stock split 4 spokes.
My 10.5's had absolutely no clearance issues on them but I have gotten used to the wider tires and am going to stick with them I think.
#34
i have the same size... I had to bash the fender a bit like right in front of the doors... where the mud flap would attach.its weird.... try this frank check it not at full lock but at half lock. mine doesnt rub at full lock only half lock LOL maybe its cause I have wheel spacers and it throws the geometery a bit. I am going to get some 32x9.5 if I can find some . I think that would give me the best performance. i need to gear up a bit these 4.10's dont like 33's........ anyone know what years use like 4.56? I want to grab some used 3rds from some junkers.
#37
hey frank, i have almost the exact same setup as you "1994 4runner, 3.0, auto, 4.88's," hows it on fuel when wheeling? and what kinda terrain are you getting into with this setup? full stuff on the ramps and real world on the trail type stuff are alittle different. with my 31x 10.5 and stock height etc i get rubbing on my front valence but i know alot of people won't.
lol hey to you two fellow bc boys above, just noticed your locations.
#38
Well I did some trimming today. I can see why 2" body lifts are recommended. I needed 2 more inches. I have a 1" bodylift awaiting install but for now it's off. My hope is these pictures can serve to show someone what they will need to do if they want to install 33X12.5's without a body lift or with just a small one (1")
I disconnect the front sway bar but left the rear on to get the most flex out of the front. I turned the wheel full lock and drove onto these ramps. This was to produce a worst case rubbing scenario.
http://sdori.com/eventimages/trimming1.jpg
This is about all the flex I typically get on the trail. I might get a bit more but usually I'm about to lift a wheel at this point.
http://sdori.com/eventimages/trimming2.jpg
The interference.
http://sdori.com/eventimages/trimming3.jpg
This shows how much up travel remains assuming I could get it to flex farther. What this means is I need to have some breathing room to accommodate this. Likely my 1" 4crawler body lift will do the trick. I just need to install it.
http://sdori.com/eventimages/trimming5.jpg
This is a view from the bottom of where I am to cut.
http://sdori.com/eventimages/trimming6.jpg
This shows the area one needs to cut and hammer.
http://sdori.com/eventimages/trimming7.jpg
Here I just need to fasten the plastic down. There is room behind it. I actually tucked the bottom into the remaining fender. This retains the splash guard functionality of the plastic.
http://sdori.com/eventimages/trimming8.jpg
Here it is with the plastic fastened down.
http://sdori.com/eventimages/trimming9.jpg
This shows the other side. I had to fold the lip back more to have some extra clearance.
http://sdori.com/eventimages/trimming10.jpg
This was very easy to do and took less than an hour. Obviously you need some of these ramps or equivalent to flex out your suspension and see where the clearing needs to take place.
Frank
The interference.
Frank
#39
Wow, I now realize how much of a difference backspacing makes. Mine are 10 1/2 wide with 4 1/2 BS running 33x12.5x15 and the closest the tire meets the inner fender at any point on the turn radius is 1". I felt that a 1" BL would help out at full stuff on mine, but I can see where you'll need more. How much trimming was done to the valance in front, I started at the bottom about 1 1/2" to 0" at the top giving me about 2 1/4" wiggle room. Can you post up some views of turning clearance.
complete rear 3rd and a semi-complete front diff
