Pics of 33's, spacers, clearance, etc...
I have two third members being regeared for 5.71's and I figured I'd pick up some 33's. Well it turns out those oh so controversial 33X10.5's are on back order for a minimum of 6 weeks. Conspiracy!!! BFG has a 2000 count back order with none being currently produced. This vexed me. I decided to get the 12.5's, now I can float on the sand.
Well guess what, they fit Ok. I'm going max out the caster and trim a little but they are close to clearing. I was expecting much more potential for interference.
BTW, for those who are afraid of steering issues with these tires. I ran 33X12.5's for over 7 years with zero steering failures and was with bj spacers. I did have the Downey Idler arm brace. This is because I did not have a front locker, I had a Truetrac limited slip. Now I have an open diff so I'm not too worried about it.
Before....
http://sdori.com/eventimages/before.jpg
After
http://sdori.com/eventimages/after.jpg
Clearance...
http://sdori.com/eventimages/clearance1.jpg
http://sdori.com/eventimages/clearance2.jpg
Hopefully this can help people to see what 33's on stock wheels will look like and what they will need to do to take care of clearance issues.
Frank
Before....
After
Clearance...
Frank
I know. But it's all good. As Superstition 10 I actually really could have used the larger contact patch. Climbing steep sand hills is a pain with skinny tires.
I have a 1" body lift (4crawler) waiting to be installed so I will do that although the clearance issues are rather minor. The 10.5's would have easily fit.
Frank
Frank
They are of the tire turned at full lock.
Frank
Frank
Could you load a pic or two of your rig at this angle, I'd like to see how they look compared to a 10.5 rim. I have a stock set of rims and 4 spare 33x12.5x15's i've been debating on mounting while mine are being powder coated.
So, I think clearing these will actually be very easy. I was expecting a much more severe interference.
Frank
Well, that assumes they pick up production enough to satisfy existing orders and fill future ones. Another bummer is the price is going up. Oil is a key ingredient in rubber and influences the prices from a host of other angles.
I'm going to see exactly what I have to do to clear these and will post up more pics.
Frank
Frank
i was warned about running the 12.'s on my 7" rims and potential problems so am kinda weary about it. I'm thinking they were worried it would pop the tire off the bead at lower air pressures mainly.
