Pic of my broken flex plate that i thought was rod knock.
Old Apr 10, 2011 | 01:41 PM
MrPeepers's Avatar
So after figuring I had rod knock, even a friend agreed it sounded like rod knock, I pulled my oil pan and replaced all the rod bearings even though they all looked ok, just normal wear. The knock was still there.
I noticed that the sound seemed to come from the bottom of the motor towards the back, so it seemed like rod 5 or 6 was knocking. But after this didn't fix it, I noticed that the noise might have been coming from bellhousing, but was hard to pinpoint. Another friend who used to be a mechanic said that he had seen flex plates crack and that may cause some strange noise. I pulled the little inspection plate off and noticed a loose bolt, but couldn't see any cracks, until I pulled the tranny off yesterday and what do I see?
Replaced with salvage yard $50 plate, BAM noise gone....
Old Apr 10, 2011 | 05:45 PM
waynesworld's Avatar
dam the devil!
Old Apr 10, 2011 | 06:00 PM
weaselman's Avatar
holy crap!
Old Apr 11, 2011 | 04:58 AM
MAD MARK's Avatar
Pretty crazy there. Was only 1 bolt loose?
Put some duct tape on it and shes good to go!
Old Apr 11, 2011 | 07:18 AM
MrPeepers's Avatar
Yeah only 1 bolt was loose. So I am guessing that maybe the bolt got loose, and that allowed the crack to start and once it started it got progressively worse. Cause the noise sure got progressively worse. Seems I may have had a few days or weeks before it was ripped in 2...
Old Apr 11, 2011 | 07:28 AM
ZUK's Avatar
ZUK
wow...very impressive
Old Apr 11, 2011 | 11:33 AM
vital22re's Avatar
totally a bro
3rd gen 4runner? 5vz? This has been showing up more and more. Also spark plugs rattle loose and the crank bolt comes loose. Oh and the transmission cooler in the radiator leaks so you get "strawberry milkshake"
Old Apr 13, 2011 | 03:38 PM
weaselman's Avatar
geez..toyota needs to do a recall or tsb if they already havent. i know its an older truck, but still!
Old Apr 13, 2011 | 04:42 PM
peckinpah's Avatar
Yeah, I agree. The thought of that thing spinning around at 5,000 RPM, just inches below my ass sitting in the driver's seat . . . very scary.
Old Apr 13, 2011 | 05:03 PM
jason191918's Avatar
because one guy didn't use thread locker and/or torque spec?
Old Apr 13, 2011 | 05:47 PM
vital22re's Avatar
totally a bro
This isn't a once happening. This is on japanese auto motors mainly on 4runners. I've seen this quite a few times.
Old Apr 13, 2011 | 06:14 PM
NwRunner's Avatar
Did you use FIPG as threadlock? FSM calls for 3 threads of each bolt covered in a threebond 1324 or equiv threadlocker. That black goo could be the reason you lost a bolt
Old Apr 14, 2011 | 07:53 AM
peow130's Avatar
A guy I knew, his cousin had the flywheel blow off his 383 and up through the floor of his 57 chevy truck.
He doesn't have a right foot anymore.
Old Apr 14, 2011 | 08:04 AM
MrPeepers's Avatar
This was what I found when I opened it up. I have had the truck about 6 years or so, so not sure who did this. I didn't see in the FSM about thread locker, just torque spec. Crap, now i gotta pull it back off?
Old Apr 14, 2011 | 08:22 AM
Outsane's Avatar
double ouch
Old Apr 15, 2011 | 02:02 PM
iamsuperbleeder's Avatar
holy crap!
took the words right out of my mouth
that's insane man!
Old Apr 15, 2011 | 02:06 PM
James Woods's Avatar
Last I heard, a lot of drag strips require cars to run scatter shields for this very reason.
Old Apr 15, 2011 | 02:08 PM
Outsane's Avatar
I think they call them Horse collars..
Old Apr 15, 2011 | 02:10 PM
xxxtreme22r's Avatar
Your thinking driveshaft safety loop, I think.
And exactly right on the scatter shield part.
Old Apr 15, 2011 | 02:12 PM
Outsane's Avatar
I see... good to know
