passenger power window problems please help
Old Feb 6, 2009 | 09:34 PM
gary96360's Avatar
the window finally started working again, i just put the door panel back on then went for a drive then i tried to lower the window and it now works, but it goes very slowly up. but when i made the window go up with battery power and wires, the window went up normally as its supposed to. you guys think the switches are shot or there is resistance in them
Old Feb 6, 2009 | 09:38 PM
gary96360's Avatar
i think the power of the spare battery i used to move the window up and down gave extra juice so it overcame the resistance of the tracks and went up fast.
Old Feb 6, 2009 | 10:10 PM
Ed H.'s Avatar
Originally Posted by Ed H.
My truck did the same thing when i bought it my window switch was very dirty and the contacts kind of bent so i cleaned them and what not put it back together worked for about 8 months and it just started doing it again it will go down perfect but when it needs to go up it wont work at all it makes me so angry i have to reach over and use the passenger switch.
dirty and bent contacts, the corrosion will cause the switch to not transfer all of the energy needed to roll the window up or down(resistence) look up
4crawler headlight combo switch cleaning and do the same thing they are almost the identical contacts even if they dont look dirty do this it will help.
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
smiley52
Jul 11, 2015 05:16 AM
ItsJustD
Jul 7, 2015 07:49 AM
coryc85
Jul 6, 2015 04:07 AM
