Passenger Power Window Problem
Old Aug 16, 2014 | 08:04 PM
ign_cas's Avatar
Hey guys, I'm having problems with the passenger window. I have an 87 SR5 4runner. When I bought it, the passenger door had a busted electrical window switch. However, I was able to roll it up and down from the driver's master window/door lock switch.
Today I carefully removed the door panel and the switch. As soon as I did that, I went to roll up the window from the master switch and nothing happened. The driver's window still worked, but not the passenger. There is no power going to the motor.
I checked the motor by connecting it to the battery and it works so I know it's not the motor. My question is: Does each door have a relay? If so where are they or it?
Does anyone have any other inputs or suggestions?
Thanks again guys.
Old Aug 17, 2014 | 02:34 AM
wyoming9's Avatar
Red face
The main control powers the other windows through the switch for that window.
If you removed the switch for your right door it won`t work That switch has two sets of contacts
When the right window switch is in neutral it allows the master control to operate the window.
Just what is your end game here??
Old Aug 17, 2014 | 02:13 PM
ign_cas's Avatar
Thanks for the help. I plugged the broken switch back in and I was able to roll the window up and down with the master switch.
Still need a bit of help though. The goal is to put 3 switches in the center console to control each of the windows. My buddy was able to do it using the exact switches as the back window like in the picture underneath.
The connector of the original window switch and a back window switch are exactly the same. Even down to the wire colors. The problem is that when I unplug the original window switch and connect the back window switch, nothing happens. No power goes to the passenger window. Here are a pictures of the connectors side by side.
My buddy is on vacation right now so I cant get to him to see how he wired everything up to work.
Any one have any thoughts to why the switches can't be directly swapped? Thanks again.
Old Aug 17, 2014 | 11:12 PM
wyoming9's Avatar
Red face
While they might look the same and have the same connectors and wire colors they are different.
I need to get out the door to work.
With a Meter you can figure out just how the back window switch works.
You plan to have both windows controlled by the switches in the console and no longer use the Master switch??
Old Aug 18, 2014 | 06:06 AM
ign_cas's Avatar
I want to have three back window switches in the center console. Just like the picture above.
I want the one on the left to control the drivers window. Middle to control the back window. And right to control the passanger window. I don't want to use the master switch anymore.
How can I go by checking the power with a meter?
Thanks again guys.
Old Aug 18, 2014 | 06:55 AM
scope103's Avatar
As always, you will stray from the correct path, unless you follow The Good Book:
http://personal.utulsa.edu/~nathan-b.../7powerwin.pdf
Unfortunately, this manual set doesn't include a rear-window switch, but just noodling the diagram tells me that the passenger-side switch and the rear-switch can't be the same, not withstanding the connectors.
But you don't really care; your plan is install a NEW system. Without the benefit of actually testing the wiring with a multimeter, I believe that the master switch leaves pins 2/3 on the passenger switch grounded when "off." The rear window switch is probably just a DPDT center-off switch, so it needs a +12 and ground to the two non-common pins. With the rear window switch, the switch then just reverses the polarity of the two "common" pins going to the rear window motor.
Why do you care? Now, the R-G and R-B wires going to the passenger switch are both at ground (and when you pull the driver's side switch, they'll both be "open.") You need a +12v and ground to feed to your replacement rear switch, used on the passenger side.
Am I sure? No. That's why you've got 10 minutes of meter work ahead of you. Just confirm the operation of the switches, and get 12v "with key-on" from the door lock circuit.
PS: I wouldn't advise skipping the meter work by just "well, let's plug it in and see if it works this time." There's plenty of ways to hook it up so moving the switch just shorts 12v to ground. In the time it takes the fuse to let go, you could ruin the switch contacts.
Old Sep 1, 2014 | 01:16 PM
ign_cas's Avatar
Scope. I'm not exactly sure what pin to test for 12 volts.
But let's go back to basics. The thing I want to do is get my power windows working.
Currently my power widows don't work. Both passanger and driver. The master switch is in operating conditions (I checked all continuity according to FSM). Both window motors work. All circuit breakers are good as well as fuses under the drivers dash. The lock button on the master switch also works.
I assume I have to check for 12V somewhere on the master switch plug. But I'm not sure where.
Anybody have any ideas?
Thanks again guys.
Old Sep 1, 2014 | 03:33 PM
wyoming9's Avatar
Red face
The blue /red wire is the Voltage into the master switch that comes from the door relay The white/black is the ground.
Make sure the ignition switch is turned to run and the battery is connected.
I forget one or both all to often
Old Sep 3, 2014 | 04:49 PM
ign_cas's Avatar
With the ignition on. I have 11.5 volts to the Brown/White wire and the Pink/White wire only.
Old Sep 3, 2014 | 11:29 PM
wyoming9's Avatar
Red face
Those 2 wires are for the door lock circuit could be why your having window problems
Old Sep 4, 2014 | 03:17 PM
ign_cas's Avatar
I assume I need to look at the Power Window and Door Lock Control Relay. Does anyone know where this is located? I looked under the dash by the clutch pedal but couldn't see much.
Does anyone have a picture of what it looks like on an 87 4runner?
Thanks again.
Old Sep 5, 2014 | 12:08 AM
wyoming9's Avatar
Red face
Door control relay is over near the ECU on the right door post area.
Old Sep 5, 2014 | 07:20 PM
ign_cas's Avatar
Is this the relay? Its behind the passenger speaker. There was nothing by the ECU.
Old Sep 7, 2014 | 04:59 PM
ign_cas's Avatar
Can anyone confirm if that's the relay? Or if they know the location of the Power Wondow and Door Control Relay?
Old Sep 8, 2014 | 12:12 AM
wyoming9's Avatar
Red face
That is your circuit opening relay.
Then given the age who knows where things could have been relocated to.
If I have time I will look and try and find the physical location if my old brain remembers.
It is the Door Control Relay
Old Sep 8, 2014 | 08:07 AM
ign_cas's Avatar
Thanks man. That would be great. If you find it could you take a picture of it as well. Thanks again.
Old Sep 8, 2014 | 08:17 AM
scope103's Avatar
This is for a '94. Unlike other parts, relays do seem to move around a little.
Old Sep 8, 2014 | 10:49 AM
wyoming9's Avatar
Red face
According to the 87EWD 88EWD It should be near the ECU maybe even inside the right door post.
As soon as the thunderstorm passes I will go look.
I just hate to shower and do laundry at the same time.
I think I see a problem just what is your production date??
86 Has the Door control relay up in the dash just to the right of the gauge cluster
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
smiley52
Jul 11, 2015 05:16 AM
ItsJustD
Jul 7, 2015 07:49 AM
coryc85
Jul 6, 2015 04:07 AM
