Part number (or name) for 22re injector grommet?
Old Nov 26, 2006 | 09:34 PM
WesternViking's Avatar
I need to replace the grommets that seal the injectors where they go into the intake manifold. I have one injector that leaks like a siv after the motor is turned off. Does anyone know what this particular grommet is called, or better yet, the part #?
Thanks,
Ben
Old Nov 27, 2006 | 04:47 AM
scrid's Avatar
Injector seal
I got mine from O'Reilly auto. Its actually a kit for sealing a single injector.
They carry two brands and prices.
For 22R:
BORG-WARNER - Injector Seal Kit
Part No: 274531 $3.49
FEL-PRO - Injector Seal Kit
Part No: ES70600 $3.99
For 3VZE
Part No: 274751 $7.49
I did buy all six of the higher priced ones which include more seals to do it right then the cheaper kit does. I figured the kits were rather costly X 6, but if ones gonna leak, others can't be far behind and I hate doing things twice.
Hope this helps.
Old Nov 27, 2006 | 12:09 PM
Thanks Scrid!
Old Aug 28, 2011 | 03:34 PM
hnugen's Avatar
Dead thread but this should help anyone avoid pulling their hair trying to find the grommet that seals the injector into manifold.
Those parts mentioned above does not have the grommet into the manifold.
Why they would sell the o-ring by itself or the o-ring & spacer collar without the manifold grommet is beyond me. The manifold grommet is the first to go due to the heat. If you're gonna pull the injectors out, it's wise to change ALL the seals.
NAPA has all 3 seals for $1.99, made in Japan. You will need qty. 4 of it.
Altrom part number: IK2401
Labeled OKF111209, cross ref #10004967
This will work for 22RE and 3VZE
www.22re.com has them for $3.09 + shipping
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
msane99
Jul 11, 2015 08:08 PM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
