Part number 180 OEM Toyota thermostat 22re
Old Oct 22, 2019 | 05:15 PM
shafner30's Avatar
I have a question what is the part number for a 180 thermostat OEM Toyota For a 1990 Toyota pickup 22re And where can I find it for the best price
Old Oct 22, 2019 | 05:34 PM
JJ'89's Avatar
https://parts.olathetoyota.com/ Have used these guys quite a bit. Very happy with service and prices. Make it easy, juts call 'em with your VIN and request.
Old Oct 22, 2019 | 05:40 PM
scope103's Avatar
90916-03078
JJ'89's advice is good. Use one of the many dealer sites (I'm partial to this one https://parts.lakelandtoyota.com/p/T...091603078.html, but I'm sure Olathe is just as good) to get the part number. Then let Google do your shopping for you! As it turns out, this dealer has pretty much the best price! (There is the cost of shipping, of course.)
Old Oct 22, 2019 | 06:15 PM
snippits's Avatar
I use McGeorge Toyota...$16.71.
https://toyotaparts.mcgeorgetoyota.c...tat-9091603078
Email them for part diagrams if you need something specific. I needed a brake line to rear brakes that was discontinued. They figured out another Toyota part number would fit, and sure enough it was an exact fit. Saved me the hassle of having to buy a brake line kit to make one.
Old Oct 22, 2019 | 06:37 PM
millball's Avatar
What's you reason for going with a 180 degree thermo???
If your engine is in good condition and tune, it should run more efficiently at 190-195 deg.
Old Oct 22, 2019 | 06:52 PM
shafner30's Avatar
Been running 180 thermostat for 28 years original engine original transmission don’t want to change
I’ve been running after market for all these years never ran OEM 180 before it actually has 490,000 on it now Didn’t have a recent picture
Old Oct 22, 2019 | 11:13 PM
ev13wt's Avatar
5 Year Member
I'd go with the dual valve one that RB from 4crawler recommends. The small valve reacts faster, giving you a more stable environment without high temp over and undershoots. Always OEM in this case, because often people will buy the failsafe ones.
90916-03070
Since you aren't tuning your engine, nor is it anything close to high performance or high compression, I would NOT run a cooler tstat. Rather, start running the correct temp range. Possibly your engine doesn'T even see "warm engine" temps and your fuel efficiency is out the window.
Old Oct 27, 2019 | 10:54 AM
old87yota's Avatar
Unless you happen to experience the "Temperature Gauge Overshoot" problem, I would personally just run what these engines came with from the factory, the 88°C (190°F) thermostat: 90916-03078.
Old Oct 28, 2019 | 08:17 AM
ev13wt's Avatar
5 Year Member
I'm gonna stick with "gradual temp change management" - it's a aluminum head on a iron block.
Katoner
May 2, 2018 03:41 PM
shafner30
Nov 20, 2017 04:03 PM
shafner30
Jan 29, 2017 08:48 AM
Jin_Chris
Jun 20, 2008 08:26 AM
Amir904
Apr 2, 2008 05:03 AM
