parking brake parts diagram?
Old Feb 21, 2009 | 12:22 PM
isaac338's Avatar
My parking brake cable just snapped, and the handle inside the cab came right out of the dash (it's sitting on the floor now).
Does anyone have a link for a blowup diagram of the parking brake assembly so I can see if it's fixable or if I should just get an entire assembly off a junker?
Thanks
Old Feb 21, 2009 | 12:32 PM
leebee's Avatar
look under the dash to see if the cable/barrel is the culprit. next spot is the pivot point under the passenger seat area of the frame. most likely a front cable assy, not too expensive but a pita if you have to work outside in the cold!
lee
Old Feb 21, 2009 | 01:00 PM
isaac338's Avatar
lee
It's broken at the pivot on the frame rail. I just want to see how the assembly in the cab is put together so I know whether it's worth fixing.
Old Feb 22, 2009 | 08:27 AM
leebee's Avatar
there are two clips on top of the trans on the firewall that you have to open to remove the old cable. right under the dash where the p/brake handle is located, on the top of the rod is located a pawl that you have to release for the handle to be able to retract to get at the barrel end of the cable.
take a look in one of the links at the top of the page of the fsm. it should detail the r&r sufficiently, hope you have small hands or a b/l as it is pretty tight between the top of the trans and firewall. i would rate it a 2 banana job, more time consuming than difficult. there are some sharp edges so take your time.
lee
ps
while you have things apart, shoot some lube into the cable housings, lube all the pivot points and you might as well check the rear brakes for proper adjustment. kind of crappy weather to do it in unless you have a garage! good luck, keep us posted.
lee
Old Feb 22, 2009 | 08:50 AM
DupermanDave's Avatar
Mine snapped a few months ago. I have yet to order the new cable, but I'm in the same situation. Waiting for warmer weather to install and buy another one.
Old Feb 22, 2009 | 08:57 AM
874runnersr5's Avatar
Old Feb 22, 2009 | 09:16 AM
turborich's Avatar
Mine snapped right where the cable meets the little aluminum end (like on a bicycle brake cable) Anyways, the cable wasn't offered aftermarket anywhere (dealer only) so I went to the pic a part & simply cut the end off of a cable & picked up some cable clamps. Then put it back together. It works fine now. I would have gotten the entire cable from the pic a part but I saw that the various years & models had different mounting brackets at the backing plates.
Just an idea.
Old Feb 22, 2009 | 10:23 AM
isaac338's Avatar
Just an idea.
That's a good idea - I've got some cable clamps kicking around and it's broken pretty cleanly. Thanks.
Is there anything that prevents the handle from coming completely out of the housing if the cable isn't attached? The diagram shows the handle inside the housing :/
Old Feb 22, 2009 | 10:56 AM
Just an idea.
Does sound like a good idea, though I'd still feel safer (personally) replacing the cable entirely. This cable has lasted this truck 20+ years, I'm sure a replacement cable will do just as good. Though, who knows, maybe your replacement idea might make it last 30 years. You can only try and find out.
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
ptb12
Jul 5, 2015 01:49 PM
