Parking brake not engaging.
Old Apr 3, 2010 | 08:54 AM
Camach's Avatar
I searched and searched before making this thread but none of the solutions from other threads have helped.
Like the title says my parking brake won't engage. It was working fine a few months ago then all of a sudden it stopped engaging. I don't have any broken cables as I pull the parking brake handle all the cables tighten up.
It's like the brake pads aren't being pushed out far enough. I tightened bell crank nut up by the T-case and that didn't tight anything up either.
I also noticed the adjustment lever falling off of the adjuster when I pull the parking brake handle to far. So I'm not sure if that has to do with anything. Also the lever hardly sits on the adjuster wheel.
http://www.ncttora.com/fsm/1993/brakesystem/11-4wd.pdf
My lack of mechanical knowledge has stumped me.
Does anyone have any ideas?
Old Apr 3, 2010 | 09:23 AM
streetlancer's Avatar
Have you tried adjusting the rear brakes? On the back of the drums there is a small oval slot covered by a plug in which you can use a flathead screwdriver to turn the little wheel that adjusts your rear brakes.
Old Apr 3, 2010 | 10:22 AM
tiger's Avatar
yes try adjusting the back breaks if that dont work depending on your funds martin crawler offers a handy dandy e brake coversion that goes on your driveshaft and is better plus you can do away with all those lil brackets and cables that r easy to damage in the big mud
jashoeuh
Nov 18, 2024 08:08 AM
skoob
Oct 15, 2015 03:23 PM
romex1
Aug 10, 2015 06:21 PM
terminator
Jul 27, 2015 07:13 PM
CanRunner
Jul 20, 2015 01:29 PM
