Overheating mystery
Old Jul 6, 2010 | 05:03 PM
mt_goat's Avatar
Originally Posted by Innervision
... Top rad hose is soft and really hot. Could it be collapsing with increased speed of water pump?
No, not the top hose. The bottom hose is the return line, it could collapse if it's a cheap hose.
Old Jul 7, 2010 | 05:52 AM
mt_goat's Avatar
This little wire coil is used in some cheap radiator return hoses to prevent collapsing.
Old Jul 16, 2010 | 08:24 AM
Innervision's Avatar
thanks, Mt goat.
I think I found my issue.
The radiator is only a year and a half old but it had pretty significant mineral deposits on the inside. I swaped out the radiator and the thermastat. The thermastat was also covered in minerals, felt like sand paper covering the radiator side. Hopefully this will fix my rising temps on hills. I think the mineral deposits were limiting heat transfer.
now I need to replace the freeze plug behind the starter (small leak there) and it will be ready to get back on the road.
Old Dec 7, 2010 | 05:10 AM
Liveforocks's Avatar
The previous owner installed the headgaskets backwards. I bent a 1/8 steel rod into a J and shoved it up the thermostat housing and poked a hole through the headgasket. Not a ideal fix but it worked
Old Dec 7, 2010 | 06:11 AM
  #25
Bojangles's Avatar
Bahahaha!!!!!
Well buddie, looks like you found your issue .
Head gasket kit from Autozone and it looks like your good to go.
ladybugRC
458
Aug 21, 2020 10:41 AM
Bourbonblues
Dec 15, 2017 05:43 PM
nvwiggins
13
Jun 16, 2016 03:05 PM
alexcarey
Oct 14, 2015 06:05 PM
LotOMiles
Sep 14, 2015 11:45 PM
