Ordered an Aussie Locker
#68
Took it for another drive tonight. To be honest, I couldn't tell it was there, no matter what I did. I'm only running 80W90 oil and I'm thinking I might not even go with the Redline Shockproof oil after all, might return the stuff I have and use cheap oil instead.
Even in the rain, I can hammer the gas on a tight uphill corner and the tires don't break loose and fishtail. The heavy rear of the 4Runner with its low power 22RE and siped AT tires prevent the rear end from kicking out. Contrary to everything I've heard, I consider this to be safer/ easier to drive on wet roads than open diffs.
#71
It seems to work best with thicker oil, once the oil heats up, its not quite as well mannered, but still good. It tends to jerk a little around some corners once the gear oil is warmer I think. I will try Redline Shockproof in a couple weeks.
justdifferentials
14
Jun 11, 2017 08:36 PM
djpg2000
Sep 7, 2015 10:36 AM
zz_denis
Sep 6, 2015 03:43 PM
