old alarm removal
Old Aug 11, 2013 | 10:57 AM
904x4's Avatar
old alarm removal
thought i'd post this as someone else might have same problem.
so i put this alarm in about 1996, either a k9 or excaliber. just a simple alarm with remote. after selling the truck to my brother in 2000, he reported a starting problem a few years later after that. i had no clue so he searched and found out that this is a common problem in trucks that had an alarm installed. seems that in the starter kill circuit a relay is installed and that after time that relay will cause the stater circuit to draw too much current so that the starter relay itself doesn't have enough juice to start. all you get is a the sound of another relay and nothing else.
earlier this me get to buy truck back.
i decided to remove the alarm. i was nervous about it but it turned out to be a piece of cake. i took out the entire alarm wires and everything. in my case all the alarm did was disable the starter when the alarm was tripped. of course it had sensors and the ole syrine. as it turned out all i needed to do was just unplug the alarm box (or cut all the wires off). find the installed alarm relay and splice the cut wires back together. i traced all of the wires of my alarm to ensure what i was doing was correct.
i kept this kind of vague so truck crooks don't get to much easy info on specific vehicles. but all in all this is a no worries removal.
just a side note: my starting trouble only happened on warm days usually over 80.
Old Aug 11, 2013 | 01:48 PM
Slowey23's Avatar
sounds easy enough, I have an alarm installed in mine from a previous owner but I found the hidden off switch. I still want to pull it out cause it is a big unit that is jammed up between the steering column and all the other electrical crap under the dash and makes it real hard to work on anything else in that area. As I have no remote for it, its useless to me, so it needs to go
Old Aug 13, 2013 | 09:26 AM
canant87's Avatar
Alarm issues
I have a 95 with the integrated system and im having the same problem, would you be able to email me at cocanant@yahoo.com to help me out? I also cant figure out which little black box is my alarm, as I have 3 boxes under my dash. thank you.
1uzRunner
63
Nov 10, 2018 03:58 PM
choppe777
May 16, 2016 08:00 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
gp66
Sep 7, 2015 08:29 AM
Aaron Logan
Sep 3, 2015 08:08 AM
