ok heres a question v6
Old Jul 5, 2008 | 01:09 PM
76ANTHONY's Avatar
Originally Posted by apalmer1
the AC compressor or speed sensor shouldnt stop the engine from starting. the TPS will, as will some of the other sensors including the AFM. in your case this truly sounds like a timing issue, you used a timing light to verify that it is at specifications? do you have the plug wires on correctly, are you certain that you aligned the cam and crank correctly before installing the timing chain?
cam timing is lined up with the marks and so is the crank. all 6 ign wires are where they are supposed to be, im tellin ya, it sounds like timing to me to, but i get it at top dead center and set the dist...i just dont know what im missing here.
im about to have my boss tow this pig to the shop and have my smog tech check it out, but he'd charge me an arm and a leg.....
Old Jul 5, 2008 | 07:24 PM
76ANTHONY's Avatar
woooohooooo shes runnin!!!!!! she runs ok but has issues. but i'll get those weeded out. i really have no idea what fixed it, but i took out all the vacuum lines again and reset the timing. she takes a while ta start but when shes warm, she starts right up.....
thanks everyone i really appreciate the help
Old Jul 6, 2008 | 09:16 AM
76ANTHONY's Avatar
drove her around the block today with the a/c, wow this sucka runs like it has some decent horsepower, now i know different, but you have to realize, i've only driven this runner with a blown headgasket and 2 burnt exhaust valves so to me, shes a runner.... then i found that because i let her sit, she decided that she would like new valve stems on her sooooo i'll take her to work and change them out. if it didnt have low tires she'd have got a little driven test and i never realized how cold that a/c was, probably cause i never used it...
Old Jul 6, 2008 | 09:42 AM
bigt's Avatar
congrats!
Old Jul 6, 2008 | 10:25 AM
  #25
76ANTHONY's Avatar
Originally Posted by bigt
congrats!
thanks, it sure feels good....
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
