oil on spakplugs
oil on spakplugs
I changed them and there was oil on the threads and white smoke comes out when I rev the engine. I have a trip to Arizona from San Diego and I don't need to break down. HELP
oil on the plugs can mean a leaking seal somewhere or the rings are going and white smoke can indicate water/coolant getting into the combustion chamber: head gasket.
take it to a trusted mech for a check up, good luck and keep us posted.
lee
lee
ohh, head gasket, sounds fun. Does it matter that I just got it pressure washed? I mean if the plugs weren't tight enough could oil+water have gotten in that way? How difficult is it to change a head gasket in the 22-re?
okay so i've decided to change the HG besides the obvious is there anything else I should change/need to change while i'm in there? Seems to be some confusion about the head bolts.
No pressure washing wouldnt cause oil on the plugs. If theres any wear on the timing chain that would be worth doing at the same time. Its not very difficult to change the head gasket on a 22re if you have some mechanical ability, and the right tools. It would probably be worth testing to ensure that it is a head gasket. It would probably be worth doing either a compression test on each cyl or a vacuum test with the engine idling.
Okay so sorry if this comes off as a total newbee, but i'm more of a audiophile but want to learn this stuff.
Here is a pic of the sparkplug that I pulled out yesterday
I pulled theh new one today after driving 4.5 miles (below)
Oil right? Side by side (old on left)
So is it a head gasket from what you see here? What will compression testing tell me? What wil vacuum testing tell me? Any help is appreciated.
hard to tell by the plugs. A compression tester plugs into the spark plug hole, and the engine is turned over. This would test to see if the cylinders have compression or are leaking. It would also indicate which cylinder the headgasket leak is in. A vacuum guage measures vacuum, and should be steady at idle. If the vacuum guage jumps at idle it would indicate either a head gasket leak, or some sort of other gasket leak (intake, etc.)
Originally Posted by kyle_22r
i don't see any problem with those plugs, really. the thing to do is pull them ALL and compare -- you can't tell a lot just by looking at 1 plug.
it goes 3,2,1,4, new Green is where the oil is at least I think it's oil. Basiclly
all over the threads
Oh yeah the only reason I mentioned the pressure washing is the 1, and 2 plug were broken off (see pics below) by the guy that did the pressure washing,(long story) but they said they would pay for new plugs and wires. Hope it happens soon.
those plugs all look fairly good. also, it might not necessarily be oil on the threads, but more of a carbon type gooey stuff. i don't think there's anything to be alarmed about.
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
