oil pump
Old Feb 27, 2007 | 03:32 AM
ssupercoolss's Avatar
oil pump
looks like i have found my oil leak. the front crank seal seems to have bit the dust. so...i figure just to replace the oil pump. i see oil pumps on ebay for like $50. are these any good? or stay away from them?
thanks
Old Feb 27, 2007 | 04:28 AM
TNRabbit's Avatar
www.engnbldr.com
Accept no substitutes. You don't want to eff around with something as important as an oil pump. Click on Toyota Hot Licks icon at the top.
Old Feb 27, 2007 | 08:07 AM
KLF's Avatar
KLF
Call engnbldr, see if they still sell that hi-flow "turbo" oil pump for the 22RE. I put one on mine a couple of years ago, and the oil pressure gauge is a full click higher all the time, good stuff!
Old Feb 27, 2007 | 11:41 AM
dcg9381's Avatar
Ted will be honest with you, last time I checked the turbo pumps were not available through him..
Be careful with other vendors - many vendors interchange the 22re and 22rte pumps. They are different - the 22rte pumps have a different pitch and are designed to be used with the 22rte front cover (they will work with both). Here's a photo of a turbo pump vs non-turbo - notice the difference in the number of holes in the crescent shape:
http://lakebox.dnsalias.com/photos/1...bo_oilpump.jpg
A 22re pump is more than adequate for a 22re and I don't think high volume buys you much. If you want a little more oil pressure, shim the by-pass. You can buy the ~$145 pump from DOA or LC, or buy just the shim as offered by LC.. You could even make it yourself with a drill press and a tap.
A higher volume pump doesn't do much for you if you don't need the volume.
Might check the FS section.. someone I know might have both a new 22RE melling pump forsale and a used DOA pump with the high-pressure bypass. :-)
I'm now running a true high volume turbo pump, but I feed the turbo with a 4AN line that does flow a sigificant volume of oil on the outside of the motor.
Old Feb 27, 2007 | 12:07 PM
PabloA's Avatar
if the front crank seal is leaking. Does that mean you probably need a new pump?
Also is the pump right behind the main seal or is there another reason your replacing your pump?
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Snort
Jul 19, 2015 07:03 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
