oil pressure question
The oil pressure gauge on my truck does not work, so I installed some autometer gauges few months ago. Saturday while in gorman the oil pressure gauge stopped working. It showed no pressure at all, but its went back to normal after about 20 mins of driving. Yesterday the same thing. Worked for 10 mins, and then nothing. I checked all the wires and they are good. I'm pretty sure its the sender, but is it possible that an engine will have oil pressure, then no pressure at all, and then pressure again?
If the oil pump drive gear was damaged or stripped.
Or if you have debris or junk floating around in your oil pan/ engine. Then yea it is..
Are they electronic or manual gauges?
Im guessing electronic since you said there was a sender...
You might want to try a fully manual gauge to see what happens.
I would take the gauge back and getanother one. Maybe its defective.. And then get a fully manual one so you can definately watch the pressure fluctuate. Then you can determine if its a pump or worn out bearing or whatnot.
i just dont trust electronic things that well.. just my own opinion.
Im pretty sure it's either the gauge or the sender from the way it goes down completly, but you never know. I agree that mechanical gauges are probably more accurate and reliable, but im just not crazy about having oil and water hooked up to the gauge. It can get messy. Is there a low oil pressure warning light in 88 runners? If there is, is it hooked up seperatly form the oil pressure sender?
well it was the gauge, but it only happens after about 2-3mins when i turn the lights on.When the lamp inside the gauge gets hot, the gauge malfunctions. What a stupid problem, but i'm glad it's nothing serious
88yodabasket
Jul 13, 2015 01:32 PM
