oil pressure question
Old Jan 13, 2010 | 08:47 AM
clk_cpa's Avatar
The oil pressure gauge on my truck does not work, so I installed some autometer gauges few months ago. Saturday while in gorman the oil pressure gauge stopped working. It showed no pressure at all, but its went back to normal after about 20 mins of driving. Yesterday the same thing. Worked for 10 mins, and then nothing. I checked all the wires and they are good. I'm pretty sure its the sender, but is it possible that an engine will have oil pressure, then no pressure at all, and then pressure again?
Old Jan 13, 2010 | 09:39 AM
weaselman's Avatar
If the oil pump drive gear was damaged or stripped.
Or if you have debris or junk floating around in your oil pan/ engine. Then yea it is..
Are they electronic or manual gauges?
Im guessing electronic since you said there was a sender...
You might want to try a fully manual gauge to see what happens.
Old Jan 13, 2010 | 10:03 AM
clk_cpa's Avatar
It is electric. the debris floating around makes sense. Would i be able to tell if the oil pump gear is damaged by the way the engine runs? I should probably do an oil change. The only thing that it seems the gauge does not get any signal. Its not like the pressure decreases and goes to 0. Its like it turns off and goes completely dead, but I read 12V so i know its not the power. It goes down to the same setting as when the gauge is not hooked up to anything.
Old Jan 13, 2010 | 11:33 AM
weaselman's Avatar
I would take the gauge back and getanother one. Maybe its defective.. And then get a fully manual one so you can definately watch the pressure fluctuate. Then you can determine if its a pump or worn out bearing or whatnot.
i just dont trust electronic things that well.. just my own opinion.
Old Jan 13, 2010 | 06:14 PM
Erik Beeman's Avatar
You better cross your fingers that that gauge is not accurate when it shows no oil pressure.
If you had 20 minutes of driving with no oil pressure, your motor would be gnarled.
Old Jan 14, 2010 | 01:02 PM
clk_cpa's Avatar
Im pretty sure it's either the gauge or the sender from the way it goes down completly, but you never know. I agree that mechanical gauges are probably more accurate and reliable, but im just not crazy about having oil and water hooked up to the gauge. It can get messy. Is there a low oil pressure warning light in 88 runners? If there is, is it hooked up seperatly form the oil pressure sender?
Old Jan 14, 2010 | 09:57 PM
clk_cpa's Avatar
well it was the gauge, but it only happens after about 2-3mins when i turn the lights on.When the lamp inside the gauge gets hot, the gauge malfunctions. What a stupid problem, but i'm glad it's nothing serious
Old Jan 14, 2010 | 10:18 PM
Glad to hear that. (that you figured out the problem, not that the gauge was messed up)
Old Jan 15, 2010 | 06:45 AM
Dan_P's Avatar
when my oil pressure gauge when aout a couple years ago i went this route $10
it was easier than dealing with the plastic line melting on the exaust
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
88yodabasket
Jul 13, 2015 01:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
