Oil Leak, unknown
Oil Leak, unknown
I spent half an hour searching for "Oil Leak" here and all I get is basically everything else. Anywho. 95 4Runner has constant leak. Replaced valve cover gaskets, Still leaks but I do not see any oil around valve covers. Does not leak when parked uphill (if that helps). Drips off of front of trans case. Thanx
Only you can find this leak. Pressure wash, use brake clean, whatever. Degrease and clean ahead and above where the leak appears.
When it's clean and dry, run it a bit and find where the oil originates. Is it motor oil, is it gear oil, is it power steering fluid????
How much does it leak????
In the past I've found a powerful light source (18v work light or similar) and a flexy engine mirror helpful for finding leaks. And on a spotless clean engine, as previously mentioned. It's near impossible to see oil seeping out when everything's coated in grime. Cover the fuse box, distributor, and coil/igniter with plastic bags during cleaning.
Gravity is not your friend. Every leak from everywhere drifts down and back and looks like a main seal. So how do you know? ...
I don't recommend a pressure washer (if your engine has that much caked on muck, who know? It may be the only thing keeping the oil IN!). You can buy spray engine degreaser at any parts store. That and a garden hose (maybe a brush too) will get your engine sparkling -- the only condition in which you can really find a leak.
Just because he has already replaced the valve cover gasket does NOT mean the leak isn't there. (How do I know that ....?) As I mentioned, if he replaced the gasket and didn't follow the FSM, it's almost guaranteed to leak. Clean the engine first. Then you'll know.
rocksockdoc
Feb 21, 2013 09:36 PM
rocksockdoc
Feb 15, 2013 07:44 AM
jdsdj98
27
Feb 21, 2009 03:17 AM
