Oil found on spark plug
Old Feb 17, 2014 | 02:29 PM
87blyota's Avatar
today I decided to look at my spark plugs cause i installed a new carb. and i was going to read the plugs to tune. All my plugs were good except #3 there was some oil on the threads and it slowly ran out of the whole. any ideas? i havnt noticed and significant oil loss it burns enough to add some by the time for a oil change.
Old Feb 17, 2014 | 07:50 PM
87blyota's Avatar
anyone?
Old Feb 17, 2014 | 09:58 PM
frm_808's Avatar
valve guides or piston rings
Old Feb 18, 2014 | 01:26 AM
Romans117's Avatar
Was the spark plug dry on the end? Sounds like your valve cover gasket is leaking oil into the spark plug hole. Never seen a spark plug packed with oil and it not fire and burn it off when running. Technically blow by could cause that but there would be other symptoms. Do a compression check on the cylinder dry and with oil and compare pressures.
Old Feb 18, 2014 | 01:37 AM
Terrys87's Avatar
Sounds like just a leaky valve cover. A picture of the spark plug would probably give a better answer.
Old Feb 18, 2014 | 05:59 AM
87blyota's Avatar
ill get a picture of the plug today but yea when i pulled it out the oil was only around the threads and not on the tip.
Old Feb 18, 2014 | 06:13 PM
Romans117's Avatar
Valve cover gasket is leaking.
bigjstang
Jun 2, 2025 03:56 PM
Johntom240
7
Jul 13, 2015 12:18 AM
smiley52
Jul 11, 2015 05:16 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Gamble_STi
Jul 7, 2015 07:54 PM
