Oh great another vibration thread!!
Old Nov 23, 2006 | 01:47 PM
Poul D'eau's Avatar
I hope you can confirm what I think is my problem.
About a month ago I started hearing a swish-swish noise when backing up... which lead me to replace my u-joints. One cap had rust instead of grease...
After replacing I had a bit of vibration above 40mph. Power on or off it didn't matter. I've been thinking it was my rear bearings but now I remember that one of the clips on the new U-joint was a lot thicker than the others.
Would that difference thickness be enough to be the cause of it? or I'm I just trying to get out of changing my bearings...
PS I hope everyone is having a Happy Thanksgiving!
Old Nov 23, 2006 | 02:13 PM
Mister Willie's Avatar
maybe, and I'm probably wrong, the weight of the one thicker clip is causing a vibration? Just taking a guess.
Old Nov 23, 2006 | 02:20 PM
Poul D'eau's Avatar
I'm thinking that the thicker clip is keeping the u joint from being centered... so the piviot point was moved to one side by a tiny amount causing the vibration.
Old Nov 23, 2006 | 02:54 PM
tc's Avatar
tc
I'm thinking something simpler:
When you put the driveshaft back in, you got it out of phase. Did you mark the driveshaft and pinion flange before you took it out?
Old Nov 23, 2006 | 03:53 PM
Poul D'eau's Avatar
I put a zip tie on it but it got broken off while convincing the good u-joint to come out...
Tomorrow I'm going to replace the clip and rotate the mounts. Thanks guys, I'll let you know how it turns out!
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
1996Taco
Jul 20, 2015 12:02 AM
