Odd droning, whining, humming sound
Old Feb 16, 2015 | 08:36 AM
tonkatruck_79's Avatar
Exclamation Odd droning, whining, humming sound
For the past few weeks I been getting this slight droning, whining sounds when driving my truck. It only occurs when moving at speeds from ~5pm - 20mph. It doesn't make a difference if i'm in gear or not, and it seems to be coming from the front wheel (behind the dash area). After 20 mph or so, the sound is pretty much gone (or the tone changes enough where i can't hear it). It is driving me nuts! I wanted to see what you all thought it could be. Here is my take so far...
1. Brake dust build up?
Ive looked at the brakes and nothing seems overly clogged with dust. The sound doesn't change when I apply the brakes, so im doubting its a rubbing/contact issue between the pads and rotors.
2. Clutch/trans issue?
The sound doesn't change tone what so ever when I press the clutch peddle or coast in neutral.
3. Electrical ground issue?
Typically when ive seen these in the past, you get a tone change with engine rpm and its always present.
4. Wheel bearing issue?
When i've had wheel bearing go out, they make a nice metal on metal sound, that gets worse quite quickly. Ive wiggled the tires when the front end is jacked up and I don't feel and play. Not to say that rules it out tho.
Video of Issue
Old Feb 16, 2015 | 08:57 AM
LSUfan71's Avatar
Speedometer cable?
Old Feb 16, 2015 | 09:04 AM
bswarm's Avatar
Try in neutral, vehicle stopped, raise RPMs very very slowly to about 2000 and see if it reproduces the sound. It sounds like a harmonic ringing from an exhaust shield or something. I've heard cracked flexplates make that noise, but you have a manual trans.
Old Feb 16, 2015 | 10:11 AM
Originally Posted by LSUfan71
Speedometer cable?
This did cross my mind. I does seem to resonate from behind the dash...
Also when I stick my head out the window, if it was a wheel bearing, you would think it would just as noticeable if not more, but it isn't. Its less noticeable.
Old Feb 16, 2015 | 10:12 AM
Good idea. I will give that a try. So far when i'm stopped, the sound is gone, but I haven't tried adjusting rpm when stopped.
Old Feb 19, 2015 | 06:02 AM
Tried this and no sound. Oddly enough when I had someone in the passenger seat the other day , the sound went away
Old Feb 19, 2015 | 08:27 AM
grumpin's Avatar
Anything new added lately? Like a front bumper or roof rack or window shades. I've heard roof racks make some weird noises.
Old Feb 19, 2015 | 04:34 PM
New items have been the full TG rock armor plus wheels and tires. No roof rack though
Old Feb 19, 2015 | 04:50 PM
grumpin's Avatar
If you can't isolate it might take one piece at a time off, I don't know what is involved with the TG armor. But it could be that.
Old Feb 19, 2015 | 07:45 PM
Yeah I could remove the front bumper. It's definitely coming from front of the vehicle. The sliders are welded to the frame.
aowRS
Sep 13, 2017 08:22 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
langry345
Sep 14, 2015 03:36 PM
ac7822
Sep 11, 2015 08:49 AM
Streetrod19772000
Sep 10, 2015 06:22 PM
