Odd Brake Pad Replacement Question (OEM pads don’t have the hole for the spring)
Old Dec 31, 2018 | 07:16 AM
Davebarbier's Avatar
It should say in my signature but I have a ‘94 Pickup 4WD IFS Manual locking hubs.
Hi everyone, I’m replacing my brakes with OEM. Pads and rotors. I’m assembling them now and the W shaped spring can’t go in the proper place because the outboard OEM pad doesn’t have a hole for it. The inboard does but the outboard is just blank. The spring is supposed to go on the bottom of the pads so it looks like a W but I can only mount it on top of the pads so it makes an M. What gives?
Part number of pads are 04465-35040
Here are the old pads before I replaced them. Yes, they’re still good.
Here’s a picture of the new pads with the outboard pad on the right. Notice the blank where I’m expecting a hole.
I could install the spring on top but that will not pull the leading edge away from the rotor as it’s supposed to be. Can’t swap the pads around as the shape won’t let them insert all the way. What’s happening here? Am I crazy?
Thanks for the help
Old Dec 31, 2018 | 07:47 AM
akwheeler's Avatar
I suspect your pad was mis-manufactured, grab a drill and make it work.
Also, those springs are "anti-rattle" springs they do not have the power to push the pads away from the rotor.
Old Dec 31, 2018 | 07:52 AM
Hmm, that would be weird since both the left and right outboard pads don’t have this hole but definitely a possibility! What do you think of just keeping the spring on the top in an M shape instead of drilling the pad?
And oh ok, anti rattle, that makes more sense!
Old Dec 31, 2018 | 10:05 AM
So odd, in searching the part number in google images I see many of them are the same as mine with a missing hole. I’m guessing they’re not actually a bad production run. But I also see one from a Russian site of the same pads with the same part number that do have the hole.
I think I won’t drill them. I’ll just mount the spring upside down in an M shape.
Thanks for the help!
Old Dec 31, 2018 | 10:44 AM
Kolton5543's Avatar
If you swap the pads to different sides of the truck, the hole will then be on bottom like you want. Shouldn't be a problem to have it in the m shape however
Old Dec 31, 2018 | 10:58 AM
That was my first thought. But the outboard pad will only go in the outboard position. It’s a different shape slightly and will hit the hub on the inside.
Glad you think the M shape is ok because I just buttoned it all up, haha. I really don’t see an issue though. In the future if someone thinks it is an issue, let me know and I’ll drill the pads.
Old Dec 31, 2018 | 11:01 AM
Kolton5543's Avatar
It will still be inboard. Don't move it in the same caliper. Move it to the other caliper.
Old Dec 31, 2018 | 11:06 AM
Crap. I didn’t think of swapping calipers. Ugh, now to do it again or not...
Old Dec 31, 2018 | 11:18 AM
Kolton5543's Avatar
If I was in the same boat as you, I'd leave it be. The spring is there to keep some tension on the pads. In the m shape they still do their job.
Old Dec 31, 2018 | 11:42 AM
Cool, that makes sense to me. I do see that the squeal indicator is on the trailing edge of the pad and not the leading edge as it’s supposed to be. Might not get the squeal, but that’s ok. I keep an eye on those things anyway.
Thanks for the help, really appreciate it. And happy new year!
Old Jan 1, 2019 | 11:05 AM
akwheeler's Avatar
what Kolton said is true, I thought you were talking about top and bottom springs (I have both on mine) where you would need both holes, there would be no issue drilling another hole. but there will also be no issue leaving your spring on top rather than the bottom.
Old Jan 1, 2019 | 12:40 PM
Yeah, I have left it as is and all seems good. I mean I go and then I stop. Hope to continue to do that.
Thanks for the help guys, really appreciate it. Hope 2019 treats you well.
KickinUPmud
Sep 25, 2013 08:31 PM
Leebo
May 31, 2007 08:42 PM
Kiff
Apr 11, 2007 09:07 AM
Runner4
Dec 29, 2003 06:08 PM
INsr5runner
Oct 10, 2003 04:28 PM
