Obd?..
Old Sep 7, 2012 | 02:05 AM
carlo082688's Avatar
Obd?..
good day, i was wondering what OBD my 92 toyota 4runner has?.. OBD or OBD II?... and where is the connector... any answers?.. tnx!..
Old Sep 7, 2012 | 02:38 AM
KnightFiyah's Avatar
It's OBD1. The best way to check for any codes is using a metal paperclip to jump TE1 and E1 (found under the diagnostic cover by your fuse box). Turn the car to ON, not to start, and count the number of times the check engine light flashes.
If it flashes repeatedly without stopping, everything is normal.
Any breaks in the flashing designate different numbers which correspond to engine codes.
Old Sep 7, 2012 | 08:00 PM
abecedarian's Avatar
More specifically, the diagnostic check connector is under the hood, above the right fender, mounted to the fuse block there. If you open the lid, you will find a diagram representing the terminals and their function.
Old Sep 7, 2012 | 09:33 PM
TNRabbit's Avatar
Old Sep 8, 2012 | 09:01 PM
thanks for the infos.. i'll check it later..
Old Sep 8, 2012 | 10:08 PM
i got error codes 12 and 14.. what seems to be the problem?.. any thoughts?..
Old Sep 8, 2012 | 10:49 PM
12- no engine speed signal sent to the ECU for 2 seconds or more after STA (triggered by turning the ignition switch to crank the engine) turns on.
14- IGF (I Got Fire) was not received by the ECU from the igniter for 4 consecutive ignition events.
Old Sep 10, 2012 | 02:16 AM
ok... i checked the connections of the igniter and distributor and the ECU... then i removed the EFI fuse for 30 seconds... jumped TE1 and E1 again and now the check engine lights flashes normaly..thanks..
pplusent
Sep 18, 2018 10:02 PM
cr@ves4wheelin
3.4 Swaps
Aug 17, 2015 07:47 AM
Colington
Aug 13, 2015 02:21 PM
rjtrials
Aug 6, 2015 07:25 PM
