O-ring instead of gasket on oil pickup tube
Old Jan 20, 2022 | 02:28 PM
jaskotmb's Avatar
Hi, I have an 1987 22RE 4Runner and just realized that instead of using the gasket for the oil pickup tube to the block, I used an O-ring (whichever metric O-ring seemed to fit in there well). There's a little groove in the mating surface between the pickup tube and the block, so I just sat it in there. I'm realizing now that I was supposed to use a (felt?) gasket. Is it worth taking the pan off again and putting the correct gasket in there? It would be a major pain, but the engine is on the stand now, so no as much of a pain as dropping the pan once the engine is back in the truck... Just seems like that O-ring should be fine, but maybe I shouldn't gamble
Old Jan 21, 2022 | 07:21 AM
slacker's Avatar
not sure if I would be confident in that , usually when there is an o-ring , it fits over a "stub" of pipe . The oil pick up tube surface is flat , I would be worried about it sucking in the o-ring
If it was me , I would put the gasket in .
I'm just finishing one up for a customer now
Jf28142011
Mar 12, 2019 01:29 PM
pathfinder
Jun 28, 2009 10:43 AM
352Ford
Dec 10, 2008 07:40 AM
Targetnut
Sep 19, 2007 08:30 AM
shoff
Jul 25, 2007 04:19 AM
