is it normal???
Old Jan 21, 2007 | 12:42 AM
david28's Avatar
is it normal???
to smell burning clutch sometimes after just doing a clutch job???
Old Jan 21, 2007 | 01:17 AM
95ToyotaPU007's Avatar
I have never encountered it. maybe you didnt completely remove all the grease residue for the contact surfaces
Old Jan 21, 2007 | 08:42 AM
tc's Avatar
tc
Did you get the flywheel turned?
Old Jan 21, 2007 | 09:12 AM
david28's Avatar
i cleaned it with brake cleaner, and no i didnt get the flywheel turned...it looked fine but there where some very light abrasions on it
Old Jan 21, 2007 | 09:57 AM
david28's Avatar
should I have had my flywheel turned?? or is it possible that my clutch isnt engaging or disengaging all the way??
any help would be appreciated
Old Jan 21, 2007 | 10:08 AM
MMA_Alex's Avatar
could not be engaging/disengaging all the way. It it recomended that you have the flywheel turned, or replaced in general.
I would try bleeding it, and make sure the pedal is in spec. After that if its still burning you're probably going to have to rip it apart again
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
creecher10
Sep 30, 2015 03:27 PM
charlie_fong
Sep 27, 2015 10:06 PM
