noob doing SAS
Old Sep 21, 2013 | 06:44 AM
  #41
Cyberman's Avatar
Originally Posted by wolf28
^^^^ I like that price lol so I'd need a 3 inch lift cuz shackles are gonna add an inch
Only thing is it dont come with the new rotors
You're not looking at the right kit then. The TG IFS eliminator kit comes with rotors, regardless of which vendor you buy it from.
EDIT: Also download and read the installation instructions, and read them again like 10 times, so you can see what you'll be doing, and why each part is required.
Old Sep 21, 2013 | 07:16 AM
  #42
wolf28's Avatar
I found the ifs eliminator kit now I didn't see the pitman arm or the extended brake like correct me in I'm wrong
Old Sep 21, 2013 | 08:08 AM
  #43
Redeth005's Avatar
Wolf. How do your current rotors and calipers look. Are they in decent condition. You can always use your current ones. Until you can afford new ones. Then just swap them out later.
Old Sep 21, 2013 | 08:11 AM
  #44
wolf28's Avatar
There like new had them.don't last year
Old Sep 21, 2013 | 08:31 AM
  #45
4x4YOTA's Avatar
i got my rotors from advanced auto parts for $50 for the pair
Old Sep 21, 2013 | 09:44 AM
  #46
Teuf's Avatar
Give Low Range Off-Road a ring,,,,, I went with them on my 3" SAS because they bothered to call me back when I first called and left a message about prices. Like its mentioned above, read and re read directions. Visit other SAS threads, get organized. If you can get a plazma cutter, use it. If you weld outside use a flux core welder, (no gas to blow away). NR211, .035. Prep your weld joints and be careful on your fit up. I went 3". I had already had a 3" rear spring, I added 3 flat additional leafs to each side, a 1" block and made 6" shackles vs the 5" ones I ordered. Almost perfect. It should settle more in the front.
Measure 12 times then weld.
Oh and I did a U bolt flip in the rear.
Old Sep 21, 2013 | 11:25 AM
  #47
v_man's Avatar
Wow! Looks great ...
Old Sep 21, 2013 | 12:03 PM
  #48
wolf28's Avatar
ok 2 questions
1.. would my v6 calipers fit on the axle
2.. on the one kit it says to move the front hanger 3/4 of an inch forward so the hysteer doesnt hit the v6 oil pan
and on trail gear it says if ur using a 3 inch lift kit that u dont have to move the hanger forward
Old Sep 21, 2013 | 12:51 PM
  #49
Xeo's Avatar
Xeo
Yes your v6 calipers will fit the SA and you don't need to move the hanger forward unless your going with a bigger lift then 3 inches. If your just doing 3 inches you weld it flush with the front cross member.
Sent from my HTC Incredible S using YotaTech
Old Sep 21, 2013 | 01:04 PM
  #50
wolf28's Avatar
ok cuz over all the 3 inch lift will actually be a 4 inch
Old Sep 21, 2013 | 03:54 PM
  #51
wolf28's Avatar
to the top
Old Sep 21, 2013 | 05:04 PM
  #52
Cyberman's Avatar
I have the same truck, had the same lift as you, and went SAS with the 3" TG kit. Other than driveshaft work, the kit comes with everything you need, including the parts to rebuild the axle.
I also got the axle gussets, big diff armor, rock rings and the dust shield eliminators.
If you've got any specific questions, I'd be glad to help you out.
Old Sep 21, 2013 | 05:13 PM
  #53
wolf28's Avatar
why does the kit come with wheel spacers?? sorry for all the dumb questions and thank you alot cyberman for the help
Old Sep 21, 2013 | 05:33 PM
  #54
Cyberman's Avatar
The solid axle is narrower than the ifs rear. The wheel spacers bring the width back to "stock".
Old Sep 21, 2013 | 05:44 PM
  #55
wolf28's Avatar
and another question should i go with 3inch lift or 3 inch HD lift
Old Sep 21, 2013 | 05:51 PM
  #56
Cyberman's Avatar
I went with the HD lift, because I had a winch bumper and a winch. But I ended up pulling the HD leaves out, because they were stiff and it sat a little too high. But there is no difference in price. You can always do the same.
Old Sep 21, 2013 | 06:29 PM
  #57
wolf28's Avatar
i got a winch and a tril gear bumper now
so ill go HD springs and if i dont like it take 1 leaf out
might go with this place they have free shipping on the kits http://www.frontier4x4.com/Trail-Gea...AxleSwapSASKit
Old Sep 21, 2013 | 06:44 PM
  #58
Cyberman's Avatar
Luke is a good guy to buy from. Superior Off Road also has deals on shipping as well. If you haven't yet, check out my build thread, that includes the SAS. If you go with the HD spring and want to change them to regular, you take out the third leaf from the top.
Old Sep 21, 2013 | 07:00 PM
  #59
wolf28's Avatar
just got done looking at ur build thread nice work bud
now what should i do about the front driveshaft
Old Sep 21, 2013 | 07:52 PM
  #60
Cyberman's Avatar
You're going to need to lengthen it. But, you'll have to wait until it is swapped out to get the right measurements.
You can also look into a square driveshaft, if you will only be using 4wd off road. Just Google it, and you'll find it.
