Noisy Injectors
Old Apr 5, 2010 | 02:09 PM
lonecountryboy's Avatar
Noisy Injectors
Does anybody else have a problem with the 3.0 and noisy injectors. I thought I had a valve out of adjustment but when I put my stethoscope on the injectors I found my noise issue. Just wondering if anybody just put a set of reman injectors or new ones. Found a set of reman online for 359.00. If you have changed out the injectors on a 3.0 let me know what you used and how they worked.
Old Apr 5, 2010 | 04:11 PM
OutlawMike's Avatar
Yup,
They were noisy before I had them serviced.
They are noisier now that they are cleaned up. Tap, tap, tap......
Everyone keeps telling me I need to adjust my valves. Grrrr, not the valves, just those damn noisy injectors.
I saw one guy who wrapped them with pipe insulation to dampen down the noise a bit. I have never gotten the motivation to pull the plenum to do that.
Old Apr 5, 2010 | 04:48 PM
AzStorm's Avatar
Some MMO or SeaFoam in your fuel might help.
Toyota injectors are inherantly noisy.
Old Apr 5, 2010 | 04:57 PM
hilux1026's Avatar
can tell you that my rig was making one hell of a racket and likewise thought it was the tappets. Turned out to be a leaky exhaust manifold tightened it and quietened down immensly
Old Apr 8, 2010 | 11:06 PM
norcal707's Avatar
how can you tell the different between the injectors and the valves?
Old Apr 9, 2010 | 07:17 AM
pruney81's Avatar
^^listen to where the noise is coming from, and the valves are more of a heavier, metallic tapping.
Old Apr 9, 2010 | 09:00 PM
OutlawMike's Avatar
Auto stethoscope. Harbor Freight has them cheap, but I don't think you have one of those in Willits. You can order one online, they are cheap and very usefull in the engine compartment.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
dbollier123
Sep 29, 2015 05:23 PM
themightykhoner
Sep 18, 2015 02:28 AM
Kytowboater
Sep 17, 2015 11:17 AM
