Noises from rearend
for step by step picture instructions for rear end 3rd member go here...
http://gearinstalls.com/billyrear.htm
Make sure the new third has the correct drive shaft flange/bolt pattern/bolt size before you swap the old one out. If you have to swap flanges you will have to reset the preload at the pinion.
Pulling the third is pretty straight forward, remove fill plug, remove drain plug, remove driveshaft, disconnect ebrake cables and brake hard lines at the backing plates, remove nuts holding backing plates on on each side, pull axle shafts(brake assembly comes off with them), unbolt 3rd.. sometimes the studs will come out instead of just the nuts, its about 60 pounds so don't let it fall to the ground.
#26
Reusing a crush sleeve or using one period on a truck that you wheel is a poor choice. Use a solid pinion spacer on a truck that goes off pavement and sees any abuse. A buddy of mine learned this the hard way last weekend. His crush sleeve crushed, ruined his gears and "inscribed" his carrier for him.
http://forum.ih8mud.com/79-95-toyota...ml#post5213613
Even Marlin Czajkowski seems to agree on this point, and says that the only instance where a solid spacer might come from keeping the two pinion bearings a hair more rigidly aligned on the pinion as they are camped between the pinion head and the pinion nut just a little firmer once preload drops to zero over time.
The preload is maintained by the staked pinion nut pressing the pinion bearings into the races. The races are set into the cast third member housing (ie: their not going anywhere). "Smacking the pinion flange against a rock and loosing all your preload" seems to me to be a myth as a) the crush sleeve serves no purpose in maintaining preload as far as I can tell, and b) the force of the impact to the pinion flange would be directed to from flange --> pinion shaft -->outer pinion bearing--> bearing race -->third member housing --->axle housing.
Recall the pinion bearing races (blue) are set into the cast iron third member.
Zuk says: "Removing a nut that has a crush sleeve under it is perfectly acceptable AS LONG AS the nut is re-positioned to the same indentation as before or it can be positioned after the indentation to increase the PPL to an acceptable number." http://www.gearinstalls.com/rickdiaz.htm (halfway down the page).
#27
Okay.
I swapped flanges, set preload, cleaned housing, etc etc.
I have the 3rd member sealed on and bolted on..
But, now theres a 1/4" gap between where the axle and drum bolts to the axle housinIs the older 3rd member not able to accept the longer axles all the way? Or do i need to put the older axle shafts in, as well.
am i SOL?
am i SOL?
#29
Can you explain to me how crushing the spacer does anything. As far as I can tell, the spacer is purely a tool for setting the preload during the initial install and its purpose is fulfilled already by the time it is ever installed in the vehicle. AFAIK, during the install, the spacer just crushes progressively allowing for a consistent preload for the pinion bearings.
That was so good it was worth repeating.
The FSM also states when you should replace a used pinion spacer. Pretty self-explanatory, on page SA-150 there. See here:http://personal.utulsa.edu/~nathan-b...35differen.pdf
Basically, no need to replace one if you haven't reached 253 ft.lbs.(for an 8" diff, 174 ft.lbs. for a 7.5")on the pinion nut without achieving a proper drive pinion pre-load. Or, if you've overtightened the nut, and exceeded the proper pre-load specifications.
zytra
Jan 24, 2019 03:16 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
