noise when releasing the clutch
Old Aug 17, 2008 | 07:33 PM
EricBirk's Avatar
First off I have a 92 pickup, 3L 5speed.
When I release the clutch I get a squealing noise(kind of like a belt squeal but more metallic sounding).
Only during engagement, when the clutch is out fully it is perfectly quiet.
Also when driving and I match revs perfectly between gears no noise either. It seems only if their is different rpm loads placed on the clutch.
I was told it was inside the transmission, that seems kind of odd to me since it does not do it all the time.
If anyone has any ideas that would be super helpful.
Thanks,
-Eric
Old Aug 17, 2008 | 07:55 PM
jason191918's Avatar
My guess would be throw out bearing or pilot bearing.
Old Aug 17, 2008 | 10:30 PM
Myron's Avatar
x2 i had that happen to me and it was my TO
good luck
Old Aug 17, 2008 | 10:36 PM
Alex 400's Avatar
x3 that's basically what mine did too. My throw out bearing chattered when it was being let out or had some kind of load on it and sure enough when i took it out today, it was pretty loose.
Old Aug 17, 2008 | 10:49 PM
drew303's Avatar
throwout bearing is going bad
Old Aug 18, 2008 | 02:33 PM
EricBirk's Avatar
Awesome.
Thanks a bunch guys!!
Old Feb 7, 2009 | 01:21 PM
SteveyCapri's Avatar
Mine is doing something similar. When I let off the clutch in 3rd or 4th gear I hear a metallic chattering noise, especially when I let off the gas too. Throwout bearing?
Old Feb 8, 2009 | 12:49 AM
Actually, the noise seems to be coming from further back, like the drive shaft or rear differential.
When any of your throwout bearings went, did you get vibration?
Old Feb 11, 2009 | 04:03 PM
jaxrunner's Avatar
Thanks,
-Eric
I have the same thing going on. My truck sat in the driveway for 7 years. I put a new motor and the noise was there. I did not replace the TOB. I have a feeling that might of been my worst mistake.
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
Dakotaneu
Aug 15, 2015 07:24 AM
norcal98
Aug 10, 2015 06:20 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
smiley52
Jul 11, 2015 05:16 AM
